kubota L3901 use
   / kubota L3901 use #11
If the tires are rubbing then you likely don't have the sway links adjusted correctly. And make sure they check the side to side sway with one of them going into tension and neither going into compression. They are not made to handle compression at all. Depending on the box blade pin/hole spacing, you can often add washers or spacers to move the arms in narrower and give more space between the tires and sway links.
If the HST whines a lot, drop a gear (lever on left fender).
   / kubota L3901 use #12
Have a L4701 which is a frame and HP jump but not as big a frame as the MX5400. If you’re thinking that big, I’d take a hard look at the MX5400 for additional loader capacity if nothing else. Both the 4701 and 5400 have width adjustable rear wheels. I don’t believe the smaller L’s have adjustable wheels but could be wrong. Agree with others if the lift arms or sway bars will hit the tires there’s something amiss with the setup rather than a problem intrinsic to the machine.
The L2501 doesn’t have Tier4 emissions. That makes it attractive to some. Like others, the regen cycle has been a non-issue for me, but I do understand the thought that leaving off the emissions is just less stuff to potentially fail.
For pulling, the heavier the better. Weight is at least as important as HP. I’m sure a MX5400 will pull a good bit more than my L despite having only a bit more HP. When running my chipper, bush hog, or generator weight is irrelevant. Loaded rears and/or wheel weights make a big difference for stability and pulling. Don’t know if you can add wheel weights to the smaller L’s or not. You can add weights to the MX and 4701.
HST whine on mine isn’t bad at all. Can’t speak for the MX. I’ve heard the smaller L’s are louder. Still for the mowing, grading, bucket/grapple work that constitutes most of the hours on mine I wouldn’t trade the HST for anything quieter. Coming from non-shuttle gear drives it’s night/day better.
While you’re pondering, hydraulic top link and side link are quite nice for grading work. Having a rear remote with a float option is helpful in some situations such as floating the sidelink to follow the existing contour when pulling gravel from the edges of a crowned road. If you do any tree work at all, a third function and grapple is an incredible work saver.
R1’s like we have on our older machines do pull better, particularly in soft dirt or mud. The R4’s are much easier on the ground so I like them for mowing and the L with R4’s does less damage to our dirt trails than our older 2WD’s despite being heavier. On gravel or packed ground I don’t see much difference. 4WD and power steering are major advantages for loader work.
In terms of cost, you might consider implements in addition to the base machine. The bigger the base machine, the more the implements cost.
Many options out there and many configurations once you’ve picked a base machine. No need to go bigger than required but I know from experience an undersized tractor is a miserable experience.
   / kubota L3901 use #13
I am in the market for a compact tractor. I am used to older iron.
I rent for maintenance on my fifteen (15) acre property from our locally owned equip store.
My first usage of a current model tractor was this rental Kubota L3901 with FEL, HST, and less than 200 hrs.
Probably 30% of contributors to T-B-N consider a 2,700 pound bare weight L2501/L3301/L3901 tractor adequate for 15 tractorable acres. The other 70% will recommend a 3,700 pound to 4,000 pound bare weight tractor for15 tractorable acres.
For not many more dollars you can purchase a 3,700 pound Kubota MX tractor. Both the L3901 and MX series are no frills economy tractors. (I am used to older iron.) All current model tractors through 60-horsepower are available with HST transmissions, which equip 90% of new compact tractors sold.
An 'MX' supasses an L3901 in each of these four purchase considerations:
When considering a tractor purchase bare tractor weight first, tractor horsepower second, rear axle width third, rear wheel/tire ballast fourth.
   / kubota L3901 use #15
So I rent for maintenance on my property (15ac) from our locally owned equip store.
My first usage of a current model tractor was a rental Kubota L3901 with FEL, HST, and less than 200 hrs.
Probably 30% of contributors to T-B-N consider a 2,700 pound bare weight tractor adequate for 15 tractorable acres. The other 70% will recommend a 3,700 pound to 4,000 pound bare weight tractorable for 15 acres.
For not many more dollars you can purchase a 3,700 pound Kubota MX tractor. Both the L3901 and MX series are no frills economy tractors. (I am used to older iron.) All current model tractors through 60-horsepower are available with HST transmissions, which equip about 90% of new compact tractors sold.
An MX is superior in each of these considerations:
Jeff - the forum has an excellent quote function, and it vastly increases the readability of replies.
First, you can start by selecting a post and hit "quote" or often "reply", and the entire post will be in a quote.
If you don't want all of that quoted, you can edit the quote part and pare it down to only show the part that you're responding to (makes your response that much more useful).
If you want to respond to two separate parts of the message, you can insert in the quoted area [ / quote ] (without spaces) to stop the quote, and then add [ quote ] (also without spaces) to start the quote up again, typically deleting the parts of the quoted message that you don't want any more. Put your responses between the two quote blocks, and it'll look like this:
I'd like to point out that Jeff didn't write
jeff9366 said:
Lorem Ipsum is simply dummy text of the printing and typesetting industry.
and I wanted to point out that
Lorem Ipsum has been the industry's standard dummy text ever since the 1500s
I think you'll find that this will get your valuable message across in a way that people can easily see why you're writing the responses.
   / kubota L3901 use #16
Praemonitus Praemunitus
   / kubota L3901 use #18
This is kinda long ...
I am in the market for a compact. Since the market is as it is, I have not bought yet. Not only is the pickins' slim, the price asking is not practical, and it is non-negotiable too.
I will try to help, but I am sure others have already said this. First, the lower arms on the three point hitch. If they rub the tires, either one, THEY ARE NOT adjusted. The sole purpose of the pin and chain adjustment is to prevent rubbing the tires. If you look at the pin adjustment, you should see adj holes and a slider slot (use only one slider or you will have slop) - This slider allows you a little lee way in hook up. Pin pin on one side and some movement to match other. My tractor is an L4701 - one step bigger in hp and frame that the 3901. But I think the 3 point is probably the same. In the pictures below, T1 is a picture of my 3 pt. The top link is upper middle (silver color) and the lower arms are the two that are the lowes in the picture. T2 is the Left arm and stabilizer. Note that only one is in th slot adj. T3 is the right arm. T4 is a Pat's quick hitch. Lets me hookup without matching hitch pin and arm holes.
Next, the whine you mention is normal. But since these machine are best run at full rpm, I don't notice it.
Next the emission thing you mentioned. It is the tier 4 epa method of filtering out diesel particles before they enter the open air. The particles collect in a filter mounted under the hood -Diesel Particulate Filter, thereby called DPF filter. The filter needs HEAT to burn off the particulates. If you run the tractor at full rpm, it will rarely need to regenerate. If you run it a cool - low rpm - it will not burn off particulate and need to eventually do it for you.
Insurance - If you purchase new from a dealer, Kubota will offer you what is probably the best insurance in the business. It covers a lot, including theft and roll over. But you can do that ONLY as long as you carry the note with Kubota - 60 months interest free.
While you are looking, you should look at the 2501, as well as the 4701. The 2501 and 3901 only differ in the hp rating. The 4701 is a larger frame, different hydraulics and capacities. If you plan on working a lot on a gravel or dirt road, moving gravel and dirt, the 4701 may suit you better because of the difference in hydraulic capacity.
Tires. In the picture, you can see my tires. They are R4 industrial. Tires are a option when you buy a new tractor. Ag tires are the farm tires we usually see for plowing and traction. R4 industrial tires are smoother, but also have traction - probably the most popular non- farm tire. Then there are very smooth riding turf tires for landscape work. Will not tear up the yard.
Last, I would be remiss if I did not mention that there other fine tractors other than Kubota.
Long, but I hope that helped somewhat.
Best wishes, Larry
   / kubota L3901 use #19
All HST Kubota tractors whine. If the noise bothers you, wear ear protection. You should anyway, to protect your hearing. That way, you can listen to music or the radio with headphones that are so equipped.
   / kubota L3901 use
yes, thanks for the replies and knowledges thru experiences. I think the 'sway arms' were bent just slightly so that adjustments were not easily or physically possible. I could see it but they just weren't adjustable. If it'd been mine, I would have taken off and beaten them straight(er). The insurance I mentioned was 'rental' insurance which would protect renter from mishaps or breakages. Photos are appreciated and familiar as those arms seem a little close too. As I look back at the first photo, clearances look nice and plenty.
The noise from the whine is irrelavent to my ears, just a note from reading about it here. My hearing has been shot for a while now, wish I'd a been more careful with it as a young'un.
2014 Chevrolet Tahoe SUV (A55853)
2014 Chevrolet...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A55851)
Tiger Mowers 80in...
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
2019 Dodge Durango AWD SUV (A53424)
2019 Dodge Durango...
1554 (A57192)
1554 (A57192)
