Typical hydraulic leak down time?
/ Typical hydraulic leak down time? #1
Dragonpharm
Pekin, IL
Mahindra 1538 with backhoe, Massey Ferguson 156 gas
I am curious what would be 'typical' time for pressure to leak down on a CUT backhoe when parked? I have a Mahindra 1538 with a backhoe that is new to me. Because we have been using it a lot I haven't bothered putting the pins in place when parking it between uses. I've noticed that after about 3-4 days the hoe will end up resting on the ground and one of the stabilizers goes down about halfway. Wondering if this is normal or if I should be looking into it?
/ Typical hydraulic leak down time? #2
That is normal for any brand. Some will hold better than others but all valves leak down to a degree.
When you park it for the day it is a good idea to lower everything to the ground. If it is a space issue where you park it then block everything so it can't fall.
I typically do lower everything. Because the machine is new to me I wanted to see what happened. Plus I don't usually get to park it now. My daughters have jumped at the chance to operate the tractor every chance they get. Not that I blame them, it's still a toy even when working it hard.
/ Typical hydraulic leak down time? #5
I have a bobcat brand backhoe I believe it’s made by rhino for them. It has very low hours on it and it leaks down very quickly from day one. I can literally watch the arm sag if I extend it straight up and out. Not very happy about it or sure if it’s normal but I just assumed it is what it is.
/ Typical hydraulic leak down time? #6
I am curious what would be 'typical' time for pressure to leak down on a CUT backhoe when parked? I have a Mahindra 1538 with a backhoe that is new to me. Because we have been using it a lot I haven't bothered putting the pins in place when parking it between uses. I've noticed that after about 3-4 days the hoe will end up resting on the ground and one of the stabilizers goes down about halfway. Wondering if this is normal or if I should be looking into it? View attachment 713813
You need to put everything down when not using. Found a little boy under a back hoe bucket once. Wasn't good. Instructions say put it down or pin it up. Front and back ends.
2025 Rake Mini Excavator Attachment (A61572)
2025 Rake Mini...
APPROX (25) ASSORTED ARMORGUARD COMPOSITE RAILING (A64281)
APPROX (25)...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2018 LANDOLL 330 S/A  DROP DECK TRAILER (A59912)
2018 LANDOLL 330...
SITREX DM-7 - 8 1/2 FT HAY CUTTER (A64280)
SITREX DM-7 - 8...
2007 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A62130)
2007 CHEVROLET...
