How much weight up front?
/ How much weight up front? #1
Jason280
Ga
Kubota L4330
For the last decade, I've done the majority of work with a Kubota L4330 (4wd w/ front end loader). I recently got rid of the 4330, ordered a new MX5400, and picked up a Ford 3910 and 3930. I'm still waiting on the 5400 to be delivered, so I've been using the Fords for primarily all the bushhogging, harrowing, and planting. Neither of the Fords have FEL's, so I am having some issues with the steering getting "light" up front...especially with the heavier harrows.
I know there are a lot of variables involved, but is there a general rule of thumb on how much weight you should have up front?
/ How much weight up front? #2
I dont know of any general rule.....and even if there was most people dont have a way to measure it. Most just go by instinct. Steering too light you need more. Rears keep breaking loos is too much up front not enough in the back.
4wd it is beneficial to make sure the front has enough weight so those wheels can actually assist. 2wd you just need enough to steer.
Those old fords are heavy tractors for their size. ~30% heavier than your new MX. Do you plan on using the same attachments with the new kubota?
/ How much weight up front? #3
Not a rule of thumb, but if I were you, I’d start with the weight rack (if you don’t have one already mounted) and add 500lbs. You can always add more suitcase weights as you go. If you start with 1000lbs, it might be ok, but if it’s too much, they end up in the shop taking up space.
I have 2200lbs on my Case-IH for a square baler and it’s just enough.
/ How much weight up front? #4
We ran many years with a heavy 5' rotary behind an 8N on pretty good hills. Nothing up front other than wheel weights, so something like a 100# per wheel.
Would have been nice to have a little more, but it generally felt ok.
If you're feeling light, throw something on there, and just add until you're ok.
/ How much weight up front? #5
I don't run any weights on my 3910. Unlock the brake pedals and steer with those. That's what I do when dragging the old heavy Ford 954 rotary. Although steering has been better since I put new tires on the front. 😎
/ How much weight up front? #6
25% of what is on the rear.
/ How much weight up front? #7
Interesting question, but it’s not the weight, it’s the torque.
That is, how far the weight is “out front” is just as significant as the amount of weight.
If it’s twice the distance you only need 1/2 the weight.
/ How much weight up front? #8
That is why the old tractors had two brake pedals, to assist in steering when the front got light. Also so the steering would not be hard when there was no weight on the back for none power steering tractors it can make a big difference.
Personally I hate the fact the newer HST tractors do not have dual brake pedals because at least for me using the brake pedals to assist in steering is an automatic reflex.
/ How much weight up front? #9
Mine has 2 brake pedals..... 2020 model
/ How much weight up front? #10
That is why i said 25%. Figuring rear axel to 3pt hooks about 1/4 rear axel to front weights........ for a typical compact tractor......
Absolutely, I've used all the same attachments with the L4330....having the bucket up front makes a huge difference.
/ How much weight up front? #12
That's actually quite surprising. The 4330 is a 3500 pound machine with a 75" wheelbase. The 3930 is 5500 pounds and 10" longer. I'm quite surprised it struggles
/ How much weight up front? #13
There is a rule of thumb, but not for our size of tractors: Answers from different OEMs (~100-120lb total weight per HP)
For the Fords, probably start with 400lbs-500lbs on the front and go up from there if needed.
Add in the FEL, and the L4330 is much closer to 5k lbs...plus, it has all the extra weight where it needs it most, out in front of the tractor.
/ How much weight up front? #15
The rules of thumb above actually do apply to small tractors as well as larger ones.
The weight split percentages don't change based on size of tractor, you still need about 25% of the total weight on the front axle to be able to steer properly, and if the front axle is driven, you need more weight than that to get much traction out of that driven front axle. That is true if you have a 25 HP compact or a 600 HP center-articulated 4WD tractor.
The tractor weight vs. PTO HP figures are based on getting good performance in pulling heavy drawn and ground-engaging implements. Many compact tractors are much lighter than this as they are largely designed for tasks where minimal ground disturbance and high PTO HP are needed (i.e. mowing.)
Regarding the OP's Fords, a 3910 2WD (I am assuming it's a 2WD as those were more common) without any ballast had 2985 lb on the rear axle and 1695 lb on the front axle according to the University of Nebraska, so it has a 36/57 split without anything on the 3-point. I am not surprised that hanging what may be a thousand pounds or more of harrow off of the 3 point may make it a little light in the front. The scientific way to ballast is to mount the implement and use a truck scale to determine axle weights, and then ballast to bring the front up to "spec." The nonscientific way is to add weight until the front no longer feels "light," particularly with going up a hill with the 3 point raised.
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
2017 Cadillac Federal 70 IN Limo - 30,529 Miles w Premium Coachwork by Federal (A63689)
2017 Cadillac...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
