LS spreading used asphalt
/ LS spreading used asphalt #1
Drewintoledo
Ohio
LS MT225HE
Loving my little LS MT225e! Already over 50 hours on it and I haven’t even put up a house yet :)
/ LS spreading used asphalt #2
Nice job! Looks like you definitely have some experience using a box blade for sure!
None really at all! I’ve used it on my septic to smooth the dirt but that was only a few passes. Thanks for the comment my head just expanded a bit! Ha
/ LS spreading used asphalt #4
Turned out really nice. Maybe a landscape rake on an angle to take the top down and push the asphalt to raise the sides.
Thank you. I’m always looking for an excuse to pick up another implement! What’s a tractor without implements anyway? ;)
/ LS spreading used asphalt #6
It turned out great! Thanks for sharing.
/ LS spreading used asphalt #7
Free asphalt millings is only a dream for me.
They go for a hefty price per ton here.
If you do a really nice grading job in the Spring, then the Summer sun will pack those millings together to make a really hard, relatively smooth, surface.
An EA rear Deluxe Scrape Blade would be a nice tool to also have.
/ LS spreading used asphalt #8
Looks good. I spread 50 Tri-axle loads of that on my driveway with a homemade landplane type blade. That stuff has made a driveway base that has stood the test of time. My drive was at least 8" thick everywhere and I have since had hot reclaimed asphalt laid over what I initially put down. My drive is 2000' and 14' wide.
/ LS spreading used asphalt #10
Nice job 🤙
/ LS spreading used asphalt #12
They won't even sell it here ... at all. They work it back into new product.
The piles here all have signs not to take, but sure have lots of spots where it is missing. A neighbor owns wide spot on side of the road where a bunch was dumped. One weekend, a loader and dump truck repositioned entire pile to our easement road, leading to their house. Unfortunately I don’t think they managed more than about inch thick so hadn’t held up that well even after rolling. Looked great for couple ofmonths.
2018 FREIGHTLINER CASCADIA (INOPERABLE) (A63569)
2018 FREIGHTLINER...
2005 Ford F150 Lariat 4x4 Crew Cab (A62613)
2005 Ford F150...
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
Gradall no crank no start (A61568)
Gradall no crank...
2023 BOBCAT T66 R-SERIES SKID STEER (A62129)
2023 BOBCAT T66...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
