Offset Rear Blade
/ Offset Rear Blade #1
Bronco82
Gold Member
Northern Ontario
B2650
I have been looking and looking for an offset rear blade for quite a while with no luck on the used market. I mean the offset which is adjusted by pulling the pin up, rotating the whole rear assembly, and then putting the pin back in. I am well aware that a lot of of the rear blades have offset adjustments in the blade, in which you unbolt it, shift it over to the distance you desire, and then bolt the blade back in. I am also aware that the rear blades do tilt, to angle them, pulling materials in, or pushing it away.
Where I reside, we have an old railbed, which has been neglected for far too long, and it now has most of the rocks pushed to the side or the hump in the middle. I also have a 200 foot gravel driveway I maintain.
Goal is to get the blade out past the tires and able to pull the pushed aside gravel back into the tire tracks on the railbed, and to push snow away from the edge of my driveway.
Is the bolt and unbolting of the blade to adjust the offset THAT big of a pain in the butt, or is the discount in cost and increase in availability well worth it?
Thanks in advance you giant wealth of knowledge.
/ Offset Rear Blade #2
I believe in the saying buy once cry once. So get the blade you want otherwise you'll always regret it. I found a used rhino 6 way and grabbed it. That was the model I was looking to buy anyway because it did everything I wanted. Finding it used was just luck. I've never regretted it.
/ Offset Rear Blade #3
I was looking for the same features in a blade that you are. I lucked up and found a used Land Pride RB3784. I highly recommend it.
/ Offset Rear Blade #4
Any type of offset blade will have lots of advantages over a fix blade.
As you are aware, the pulling a pin to adjust the blade position is a great time saver.
How often do you see yourself adjusting the offset? If it is a rare thing then the loosen a few bolts should not be a huge deal. If it is a frequent thing then wait to find the one you want.
/ Offset Rear Blade
Buy once and cry once. That is a great quote, and it does make sense. Thank you for that.
And time and convenience, for sure, the ability to just lift the pin out, turn it, and pin back in and done.
I actually don't PLAN on having to move the offset quite frequently, like not on a daily, weekly, or monthly basis by any means. But on a job by job basis, however often that occurs.
I suppose it comes down to, is what is my price for convenience, when I do need it.
/ Offset Rear Blade #7
Take a look at the..... EA Deluxe Scrape Blade.
It is the most versatile and easy to use blade on the market.
It has every possible adjustment, and a major offset capability!
/ Offset Rear Blade #8
Every major and many minor manufacturers make blades with angle, tilt and offset. Often not a huge volume seller, never at the low end of the pricing scale. Finding a used one the right size could be a challenge.
/ Offset Rear Blade #9
I was all set to buy the EA deluxe scraper blade myself, but they replied to me recently that lead time was 12-15 weeks, and that was just a guess. Plenty of reports of people going close to double their estimated lead times on implement and attachment orders from them this summer. So I had to grab a cheaper, temporary used blade off FB-marketplace to make sure I have something before the snow hits. No offset for me.... for now.
/ Offset Rear Blade #10
I have this same blade with hydraulic angle, very sturdy, haven't bent anything in 8 years! I highly recommend it also.
/ Offset Rear Blade #11
I would highly recommend that whatever blade you initially buy,
that it have the tilt, angle and offset capabilities,
Also even if you do not intend to do so I would be sure that it has the ability to have
all of the operations performed hydraulically.
I have the tilt and angle on hydraulics in this photo.
The offset is still manual in this photo,
I do have another diverter valve and a cylinder that needs a bit of welding to add in to this unit.
With 2 diverter valves I will be able to control all three function using one tractor remote.
Just another "round toit".
/ Offset Rear Blade #12
Very nice......but hydraulically operated, you are talking about a mucho expensive rear blade
/ Offset Rear Blade #13
I have a Howse offset rear blade and I like it. It is a handy feature. That said if you find a good rear bade with a manual slider offset (loosening bolts) at a good price, buy it and treat yourself to a Milwaukee M18 heavy duty cordless impact wrench. Win - Win :)
/ Offset Rear Blade #14
The EA blade does not require any tools to offset, and does not need a gorilla to slide it.
I have a King Kutter 7' sliding offset blade.
Anybody want to buy it? I do not have a gorilla to include.
/ Offset Rear Blade #15
A used Woods slider would be a dandy blade.
/ Offset Rear Blade #16
Exactly 2 posts after saying hydraulics on a scrape blade were expensive. Fact is, cost, convenience, economy and inexpedience are in the eye of the user.
/ Offset Rear Blade #17
/ Offset Rear Blade #18
I used a Ford 11 ft hydraulic adjusted blade that I picked up for $1100 at an equipment dispersal auction.
Then I let the farm have that blade (was worried that my new tractor might have trouble handling it) and swapped for a Deere manually adjusted blade for several several years,
now I have a 10 ft Allied I picked up for $500 and am adding the hydraulics to .
/ Offset Rear Blade #19
It's not always possible to buy the implement you want. Sometimes you have to buy for the tractor and budget you have at the time.
I have a landscape rake and a grader blade I bought when I had a little 855 John Deere. They are too small for my 4310 but I have gotten plenty of use out of them. One day I may find some upgrades. As I do I will sell what I have. I'd be willing to bet I sell them for dang near what I paid new for them since prices have doubled.
My grader is a Kodiak brand offset with the slots. You loosen the bolts and slide it to one side or the other. With my current tractor it still doesn't really get outside my track. The pivot has worn to the extent I had to replace the pin with a bolt. If I want to rotate it I have to remove the bolt and nut then tighten them back down. I have had it loosen and slide out to the the extreme of the offset slot when I used it in a position other than straight on. I re-centered and leveled it the other day and tightened it with my 1" impact so maybe it will stay put. I don't recomend this model but if it's what you have you can grade a road with it. It's just going to take more time than it would with a better blade.
/ Offset Rear Blade #20
I moved up to a Bush Hog 90-08, and it IS an 8 way blade...
It's built quilt quite heavy, and I got it for a good price because the dealer had set on it, for quite a while.
I'm with the "buy once, cry once" crowd...
SR
WIRE GRATES FOR AXLE FLOW COMBINE (A63745)
WIRE GRATES FOR...
Bobcat Skidsteer Snowplow
Bobcat Skidsteer...
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59910)
1985 GREAT DANE...
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
