CK35 Engine RMP vs PTO rpm
/ CK35 Engine RMP vs PTO rpm #1
WiKioti
Eau Claire, Wisconsin
CK35
I have a Kioti CK35, bought a Woods BB60 5' rotary cutter. What engine RPM gives me 540 rpm's at the PTO. I've look in manual did not see anything. Max engine rpm red arrow on dash shows 2600 rpm's. Doubt it's that number, maybe lower. I run a 5' tiller at 2200.
I anticipate engaging the Woods at a lower rpm about 1200 rpms, just need to know answer to above.
thanks wikioti
/ CK35 Engine RMP vs PTO rpm #2
thanks wikioti
The "redline" on a tractor tachometer does not mean the same thing as it does on a car. That red line is the PTO indicator for 540 PTO RPM which is 2600 engine RPM. The governor on the tractor is set to protect from over-revving. Best advice is "Let'R rip"!
/ CK35 Engine RMP vs PTO rpm #3
Cant get to your manual in English (do you have one?) but the Spanish version says ~2500rpm for the PTO 540rpm. (tresaro is 'rear')
CK3510's is 2400rpm for 540 PTO. 2600 max engine RPM.
  • Screenshot 2021-09-11 at 19-15-08 CK25,27 30,35(M27)-SP-ALL-120917 pdf.png
1992 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1992 AM General...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59905)
2018 FREIGHTLINER...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2014 LOAD KING BELLY DUMP TRAILER (A58214)
2014 LOAD KING...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
PALLET OF MISC SIZES OF AIR VENT HOSE (A60432)
PALLET OF MISC...
