What are these connectors called?
/ What are these connectors called? #1
thegoulais
Compbellsport, WI
John Deere X584 and Ford F 1100 4WD
/ What are these connectors called? #2
They look like SAE ORB (O-ring Boss) in the valve and female swivel pipe where hose attaches.
depending on valve make also possible could be BSPP in the valve
/ What are these connectors called? #3
The male ends (in the valve) look like SAE also called ORB (O Ring Boss) the female ends to the hoses look like female swivel NPT (National Pipe Thread)
/ What are these connectors called? #4
too many look the same but different. remove them and take them to a hydraulic shop to match them up. will save a trip or two.
/ What are these connectors called? #5
From what I've read, disassembling and reassembling NPT induce leaks so personally, I bought different combinations of fittings and only used the one that I needed and returned the rest.
/ What are these connectors called? #6
While this is probably true I would liken it to the fact that you are more likely to have an accident driving your car than if you left it parked.
/ What are these connectors called? #7
From just a visual inspect I'd say that both post 2 and 3 had the correct answer.
As far as reusing them replace the O-rings (should be less then a dime each) and use a bit of pipe dope on the male threads.
/ What are these connectors called? #8
Yup, look like standard ole ORB fittings. No thread sealer required
(INOP) 2004 PETERBILT 378 T/A DAY CAB ROAD TRACTOR (A62130)
(INOP) 2004...
Topsoil Trommel (A57453)
Topsoil Trommel...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A59228)
2015 Chevrolet...
PJ Trailers 84"x15' Roll Off Dumpster (A60462)
PJ Trailers...
UNUSED LANDHERO LDH-LB9510 LEAF BLOWER (A62131)
UNUSED LANDHERO...
