Battery based electric vehicles of today and tomorrow.
Status
Not open for further replies.
/ Battery based electric vehicles of today and tomorrow. #4,341
Why are wheel-mounted motors a bad idea?
unstrung unsprung mass” is the buzzword. The more your wheels weigh the harder they hit bumps. Also the road impacts must be borne by the hub centric motor. A driveshaft is a cheap simple means of reducing unstrung unsprung mass, increasing reliability, improving ride.
The hot setup these days is to mount rear brakes inboard, between differential and halfshaft to wheel.
Edit: darn predictive speller.
/ Battery based electric vehicles of today and tomorrow. #4,342
Don't know if its a bad idea or not, but there's sprung and un-sprung weight. I learned about this when I ran my street bike hard and wanted to improve performance AND handling.
Anything that rides above the suspension is sprung weight (it rides on the springs).
Anything that rides below the suspension is un-sprung weight (it doesn't ride on the springs).
The way I understand it is that you want the suspension to be able to keep your tires in contact with the road as much as possible. The heavier the un-sprung weight (tires, rims, rotors, brake components, wheel motors, etc.), the harder the suspension has to work to keep that weight pushed down against the road.
Make sense?
/ Battery based electric vehicles of today and tomorrow. #4,343
”unstrung mass” is the buzzword. The more your wheels weigh the harder they hit bumps. Also the road impacts must be borne by the hub centric motor. A driveshaft is a cheap simple means of reducing unstrung mass, increasing reliability, improving ride.
I think it's un-sprung, not unstrung, but you have the thought process correct.
/ Battery based electric vehicles of today and tomorrow. #4,344
Will there be Old EV Car Shows? Oohing and aweing at those electric motors :sick:. This sure will change that slice of Americana, there is nothing really like looking under the hood at an Old Car Show to many of us. Oh well, there is still paint and upholstery.
/ Battery based electric vehicles of today and tomorrow. #4,347
/ Battery based electric vehicles of today and tomorrow. #4,348
This is what I have under my Tesla Model S hood ("frunk" in Teslaology):
/ Battery based electric vehicles of today and tomorrow. #4,350
Make sense?
Yes Thanks.
Here is an article that goes into detail on the extra unsprung mass of the wheel mounted motors in an EV.
"Lotus found that the impact of increased unsprung mass, though noticeable to a trained driver, was really not all that significant."
BYD unveils two electric trucks
Sounds like Warren Buffett made a good call on China heavy EV trucks. I see they come with the fire resistant batteries too.
/ Battery based electric vehicles of today and tomorrow. #4,354
This sounds like it could make a good wheel mounted motor. A doubling of the torque sounds positive.
For a performance car, this is the way to do it. Four wheels, four motors, four sets of traction control sensors and controllers.
/ Battery based electric vehicles of today and tomorrow. #4,355
When modern EVs were first talked about a number of years ago I always thought they would have a motor per drive wheel. It would seem to me that all of the slip/traction/AWD/cornering/eco/etc. functions would be easier done purely by wire. It did not dawn on me that there may still be one motor.
/ Battery based electric vehicles of today and tomorrow. #4,356
Yes Thanks.
I suspect the sprung mass of a large battery will do a lot to keep the car on the road.
/ Battery based electric vehicles of today and tomorrow. #4,357
my 66 e type had inboard rear disc brakes. supposedly you could access the rear break pads from above, thru the floor.
not
end of the day, easier to drop the whole rear end.
i thought they were cool but in the end, PITA.
/ Battery based electric vehicles of today and tomorrow. #4,358
Some time ago I watched a show on Discovery about experimental military Hummers powered by lithium batteries. They had a motor on each wheel as you say, and by running each pair in opposite directions they could pivot it in one spot.
Status
2016 CHEVROLET IMPALA CAR (A66091)
2016 CHEVROLET...
2019 ALLMAND LIGHT PLANT (A67714)
2019 ALLMAND LIGHT...
2017 John Deere 331G Compact Track Loader Skid Steer (A66734)
2017 John Deere...
CAT D6 SU Blade / Arms (A68134)
CAT D6 SU Blade /...
HYDREMA 912HM ARTICULATED DUMP TRUCK (A65056)
HYDREMA 912HM...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
