My new pressure washer is haywire. Helllllp
   / My new pressure washer is haywire. Helllllp #31
I think $55 for Pape' to simply check the washer was far too expensive. Five minutes of inspection? Nah.
   / My new pressure washer is haywire. Helllllp #32
That $55 was really the "CO-PAY" for the doctors visit to have the guy's shoulder checked,, after the same thing happened to him,,,!! o_O
   / My new pressure washer is haywire. Helllllp #33
Rotate the black knob, circled, on your machine to lower the pressure out put.
Hold wand trigger open with left hand and pull starter rope with right hand.
After starting rotate black knob to desired pressure.
My washer has same engine.
This how I start it.
Good luck.
Not all pressure washers using the GX390 are necessarily built with the pressure release that yours has.
   / My new pressure washer is haywire. Helllllp #34
I have an Excell washer with a 10 HP Briggs motor. the ony way I can start that is with water on and flowing freely with the pressure hose disconnected. I let it run to clear all the air out of hose and pump.
While disconnected I start the washer and let it run for a minute or so.
Then I shut it down and connect the HP hose up again. Then I hold trigger open while cranking. I generally starts fairly well going through that process. If not it will not start.
And now, a word from our sponsor... Howdy and this is the latest on my Honda Motor saga.
It is Wednesday evening. Monday I took it back to Pape' and said It doesn't work. Fix it fix it fix it and if you can't deal with warranty issues I don't care. Fix it. I spoke with one of the shop service guys and THE lead small engine and mower mechanic... again. They heard my dissatisfaction with their diagnosis. I was polite and firm.
After dropping it off I phoned both the Northern Tool and Honda representatives I have been corresponding with. I told them both about the process I was going through and that I felt it prudent to keep them informed of what was going on. It is important to be civil and keep records of all conversations and interactions. That was my intention to keep that channel open.
Today there was a message left on my phones from the mechanic who said the cam shaft is faulty and the whole problem will be resolved with Honda Warranty completely on board for it. I did not hear any type of apology for a misdiagnosis.I will get details maybe tomorrow when I return the call. After I get more details I will again contact the two aforementioned reps via phone and inform them.
At this point it seems my motor will be repaired or replaced and expenses not including my headaches and travel time will be covered. stay tuned.
   / My new pressure washer is haywire. Helllllp #36
Oh....but didn't they claim the problem was operator error?
At LEAST a verbal apology would be in order!
   / My new pressure washer is haywire. Helllllp #37
Ah yes....the cam normally has the decompression mechanism attached to it.....see post #10.
   / My new pressure washer is haywire. Helllllp #38
Wow, my neighbor has a Honda model and is complaining of the same thing. I’ll show him these posts. I have a Rigid brand pressure washer that is a beast with a Subaru engine. Never saw a Subaru small engine before buying this one, didn’t know they even made them. I found that if I hold down on the wand trigger and let all the air out of the water hose and spray hose it starts easily.
   / My new pressure washer is haywire. Helllllp #39
I thougtof making something that attaches to the sprayer to hold the handle in the on position while cranking the engine overwhile starting. Might make starting a mite easier.
   / My new pressure washer is haywire. Helllllp #40
That may not be a good idea. The pressure from the spray wand it pretty huge, the wand may take on a life of it's own after the engine starts.
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2021 Toyota Rav4 AWD SUV (A55853)
2021 Toyota Rav4...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
202474 (A54757)
202474 (A54757)
2014 Toro Workman HD 07369 Utility Cart (A55851)
2014 Toro Workman...
Man Basket Forklift Attachment (A55851)
Man Basket...
