NH TD95D Hydraulic Issue
/ NH TD95D Hydraulic Issue #1
LHF2019
NWPA
IH1586, JD2350, JD2355, JD2950, JD4040, JD4430, TD95D
I have come across this site on occasion for some issues on my equipment but now have an issue, joined and hope I can get it resolved.
I have a 2007 NH TD95D with 3521 hours and this week lost scv hydraulics. So since new when changing the hydraulic filter it gets air locked and can take awhile to get hydraulic oil to scv and 3pt. I changed filter 3 hours ago and hydraulics were not starting up. Ended up taking filter off filling with oil and instantly all was good. Went and started round baling and 50 bales in lost scv's. Went back next day and put gauge on scv and nothing and filter full of oil. There was no odd sounds before during or after the issue. Looking for ideas on what to check next.
Thank you in advance
/ NH TD95D Hydraulic Issue #2
I presume you checked the fluid level in the rear axle. Are you sure that the hydraulic connections are positively hooked up ?Does your three point work? If you have a loader, does it work? How about the power steering?
If they are all working (both the steering pump and the main hydraulic pump), that would rule out a failed hydraulic pump. How about the linkage on the offending valve? Is it opening and closing the spool?
Ended up shearing key off hydraulic pump shaft, broken lock washer and nut was off end of hydraulic shaft.
New hydraulic pump and back in business.
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
2012 HIDEOUT BUMPER PULL (A67714)
2012 HIDEOUT...
1999 Express Trailers 22ft. T/A Enclosed Cargo Trailer (A66738)
1999 Express...
2021 Forest River Salem FSX 280RTX 30ft Toy Hauler T/A Travel Trailer (A66738)
2021 Forest River...
OK TRUCK & TRAILER SALES PRESSURE WASHER TRAILER (INOPERABLE) (A67714)
OK TRUCK & TRAILER...
2017 Ford E-450 Super Duty Shuttle Bus (A66736)
2017 Ford E-450...
