Hydraulic leak
/ Hydraulic leak #1
sparky8027
Massey Ferguson Gc 1723 Kubota B 1700
Hi guys, I need to replace the bolt joint on my Kubota B1700 delivery line going to the 3 point hitch control valve. My question is what is the torque setting for this bolt that has 2 copper sealing washer with it. I have the manual but it shows 2 different torque specs 25.3 - 32.5 ft-lbs and 43.4 - 57.9 ft-lbs. I have ordered the bolt and washers and there is no torque settings with the parts. I don't want to under torque or over torque this bolt as the bolt has hydraulic fluid running thru it and I don't want to take everything apart to torque it to the higher setting. Thanks in advance!
/ Hydraulic leak #2
Page 3-S6 of the WSM lists the torque at 25.3 to 32.5 ft-lbs which is consistent with other models.
/ Hydraulic leak
Thanks whitetiger I found those torque specs but also on pages 2-S2, 2-S6, 3-S13 and E2-S1 they show the specs for 43.4 to 57.9 ft-lbs am I reading this right?
/ Hydraulic leak #4
You must have an older manual than what I am looking at, I am viewing the latest version from the Kubota Dealers Portal. I believe yours has a mistake or two.
It appears that 25.3 ft-lbs to 32.5 ft-lbs is the correct torque.
  • B1700_2-S2.pdf
  • B1700_2-S6.pdf
/ Hydraulic leak
Thank you, my manual must be wrong, it is from the 1990's and it is not the same as the 2 pdf files you just sent
2003 Ford F-350 4x4 Crew Cab Flatbed Truck (A66736)
2003 Ford F-350...
2011 JET  48 FOOT SPREAD AXLE STEP DECK TRAILER (A67714)
2011 JET 48 FOOT...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2006 INTERNATIONAL 4300 4X2 S/A DUMP TRUCK (A66091)
2006 INTERNATIONAL...
2010 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2010 INTERNATIONAL...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
