Hydraulic leak
/ Hydraulic leak #1
sparky8027
Massey Ferguson Gc 1723 Kubota B 1700
Hi guys, I need to replace the bolt joint on my Kubota B1700 delivery line going to the 3 point hitch control valve. My question is what is the torque setting for this bolt that has 2 copper sealing washer with it. I have the manual but it shows 2 different torque specs 25.3 - 32.5 ft-lbs and 43.4 - 57.9 ft-lbs. I have ordered the bolt and washers and there is no torque settings with the parts. I don't want to under torque or over torque this bolt as the bolt has hydraulic fluid running thru it and I don't want to take everything apart to torque it to the higher setting. Thanks in advance!
/ Hydraulic leak #2
Page 3-S6 of the WSM lists the torque at 25.3 to 32.5 ft-lbs which is consistent with other models.
/ Hydraulic leak
Thanks whitetiger I found those torque specs but also on pages 2-S2, 2-S6, 3-S13 and E2-S1 they show the specs for 43.4 to 57.9 ft-lbs am I reading this right?
/ Hydraulic leak #4
You must have an older manual than what I am looking at, I am viewing the latest version from the Kubota Dealers Portal. I believe yours has a mistake or two.
It appears that 25.3 ft-lbs to 32.5 ft-lbs is the correct torque.
  • B1700_2-S2.pdf
  • B1700_2-S6.pdf
/ Hydraulic leak
Thank you, my manual must be wrong, it is from the 1990's and it is not the same as the 2 pdf files you just sent
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
2006 PETERBILT 379 (A67714)
2006 PETERBILT 379...
2016 Ford Escape SUV (A66738)
2016 Ford Escape...
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
Kubota 76" QA Bucket (A64912)
Kubota 76" QA...
