   / Share Pics of People Hauling or Towing Something Wrong #15,181
Montreal Quebec has lots of bridges marked as low on major roadways, and no warnings. Or directions to get around them.
Many drivers stop at these things and then a local trucker comes by and says "go ahead". "Lots of room". Or, "you'll fit, just go slow
and don't hit a bump that may bounce your trailer too much".
Then they usually go through first to prove it.
You'd think it would be easier to replace the signs than have a truck stop in the middle of the road.
(I could go on and on about trucking in Montreal).
   / Share Pics of People Hauling or Towing Something Wrong #15,184
So, 15 ft is 4.57m. Those extra 7 cm really made the difference.
   / Share Pics of People Hauling or Towing Something Wrong #15,185
The trainer said:
"Bad things happen at the scale house ... travel the back roads"
   / Share Pics of People Hauling or Towing Something Wrong #15,188
Looks like it was over height and took out the stabilizer links between the trusses.
Definitely had nothing to do with the "Weight Limit 6 Tons" / No Trucks
Or maybe he figured he's not driving a box van that didn't apply to him
   / Share Pics of People Hauling or Towing Something Wrong #15,190
^ 15 feet and still jammed tight?!? That doesn't seem right.
European setup, 2 axle COE with a 3 axle trailer. In Europe standard trailers are not higher than 4 meter. In the UK apparently overweight/height/width permits are obtained as easy as brown bread, so maybe this trailer is a UK special thats higher.
Although the sign is definately wrong, this trailer is by no means taller than 4.5m
Asphalt paving can be a ***** though, when i went to school there was an overpass under which they repaved the surface. The added 10cm caused a lot of truck jams, that had been passing under there for a decade.
1993 FORD F-350XL SINGLE CAB FLATBED TRUCK (A51406)
1993 FORD F-350XL...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2017 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A58017)
2017 FREIGHTLINER...
2018 Dodge Ram 5500 4x4 Crew Cab Utility Flatbed Truck (A55973)
2018 Dodge Ram...
Bucket (A55973)
Bucket (A55973)
2021 Kubota SVL75-2 Track Loader (A56435)
2021 Kubota...
