CK3510SE ROPS wire diagram?
/ CK3510SE ROPS wire diagram? #1
pcustoms
VT
Kioti CK3510SE
Last fall I quickly added a 3 LED light bar (mounted to the ROPS with magnets) and wired up to a switched cord plugged into the cigarette outlet. Worked fine, was quick and non invasive while I was working on other projects.
Past 2 times plowing I noticed the lights would dim about 3/4 way through, chalked it up to cheap lights.
Got an unexpected storm today so went out to swap implements and cleanup, had just pulled out of shed and bam, got dark. Appears to be no power to the 12v outlet. Checked the fuse real quick and it seemed fine, but wasn't super interested in playing around in the dark in the snow. Made due with just the headlights, parked and came in.
Either I had the wrong fuse or something underneath is loose. Figure a diagram will help diagnose and next summer I can wire everything proper.
Bumping this, it's almost fall and I'll need my lights soon.
/ CK3510SE ROPS wire diagram? #3
When you check the fuses did you use a test light? Is anything else that uses 12v not working?
I like using a test light for checking fuses. If light comes on with touching both sides of the fuse then I am good there. Often times with loss of power but fuses are good it turns out to be a ground problem.
/ CK3510SE ROPS wire diagram? #8
Is that a joke from Bad Obsession Motorsports? :)
LOL...not sure of the reference. Actually the Kioti pdf shop manuals are in color but the printed manual is B/W.
I hope the OP likes it as much as @deezler, wasn't sure if he was serious or joking, his tag does not mention Kioti.
/ CK3510SE ROPS wire diagram? #9
Oh I was serious. That's an awesome reference tool to obtain for free. Probably what, hundreds of dollars from a kioti dealer for a copy?
Yeah I don't have a kioti... yet..... currently waiting on my equipment loan to close so that I can drive across the state and pick mine up. Don't worry I will post a couple threads soon.
/ CK3510SE ROPS wire diagram? #10
I have been very happy with mine. Which one are you getting?
/ CK3510SE ROPS wire diagram? #11
Sorry, I can't divulge that or talk about it until I know it's real! I've been almost nauseous since the middle of last week when, a) I found a deal no one else had jumped on yet, and b) my wife somehow agreed to let me blow a huge chunk of our savings on the down payment, and get a 7-year loan for the balance.
/ CK3510SE ROPS wire diagram? #12
You're gonna need therapy! :ROFLMAO::ROFLMAO:
/ CK3510SE ROPS wire diagram? #13
"You're gonna need therapy! "
Seat time on the new tractor will cure that...
/ CK3510SE ROPS wire diagram? #14
Loan is approved and ready. Heading out tomorrow. I'm too reluctant to share the sale ad or pics though. No post here until I get my OWN pics with it loaded on the trailer lol.
/ CK3510SE ROPS wire diagram? #15
I never make web statements as to what I bought a tractor, car or truck for as it's "out there" forever and kills bargaining down the road as a number a few years later tends to ignore the realities of a here and now situation. Covid makes a great e.g. of what I'm saying-my 2019 SUV will sell for near what I paid new as a used car. My 201 Kioti bought in 2017 is similar thing.
I don't see why you need a wire diagram to install & use some aux lights? I've installed several led lts on motorcycles and more often than I like they die. I'm a non-believer on the 50,000 hours stuff from my own experiences.
/ CK3510SE ROPS wire diagram? #16
sounds like you could be loosing ground connection in the pivot pins. Do you have a dedicated ground wire running to the lights?
/ CK3510SE ROPS wire diagram? #17
Im thinking ground myself. A bad ground can make lights go dim then out.
/ CK3510SE ROPS wire diagram? #18
If they are mounted by magnet and plug into a cigarette lighter type outlet, it is likely that the ground is carried in the wire rather than chassis. I would ask OP what happens if he wiggles the plug around? Maybe he already figured it out, since he hasn't been back since bumping the post yesterday AM.
/ CK3510SE ROPS wire diagram? #19
Ya, but the wiring on 12volt cig outlet may not be tight, or plug loose. I just know leds dont play nice with loose grounds. Could also be Chinese special lights. I had a set of ebay chinese special back up lights for my work truck. Didnt even make it thru 1 winter. I switched out to Cree lights 5 years ago, still going bright.
I used a multimeter and I am pretty sure swapped fuses. Everything else works as far as I know.
Digging in this afternoon.
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59906)
2016 FREIGHTLINER...
2012 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A60352)
2012 Kenworth T800...
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
2018 Komatsu D61PX Crawler Tractor Dozer (A61567)
2018 Komatsu D61PX...
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
