I've done a search here and haven't really found a similar problem. All of my headlights, tail lights, 4 ways, turn signals etc. work correctly. Everything on the tractor seems to operate correctly. The only issue is with some of the indicator lights on the instrument cluster. The headlights indicator, parking brake indicator, and PTO indicator lights do not work. I just noticed it today and I don't recall the last time I remember seeing them work, so it has been a while. I pulled the instrument panel loose and the bulbs for each are working OK when switched to another indicator. All of the fuses appear to be OK; I checked them all by pulling out and checking continuity. The 2 main inline 50 amp fuses along the battery and wiring harness are fine also. There does not appear to be any damaged wires or connectors that I can see. It seems odd that only 3 of the indicators don't work.
I installed LED work lights on the ROPS a few years ago and they are working fine and shouldn't have anything to do with the indicator lights anyway. The only other thing that I have done is bypass the seat safety switch because those wires kept getting pinched under the seat and shorting out the solenoid/ignition circuit.
Is this something that is going to have to be chased by an electrical guru with an entire machine schematic or am I missing something simple?
