New member - Upgrade from semi-ancient
/ New member - Upgrade from semi-ancient #1
kennywayne
Central Alabama
Kioti NX5510CH
I did a thing.
I had an OLD Kubota B1500 that finally needed brakes, tires, the mid-mount mower couldn’t be fixed anymore, and I just got tired of figuring out a way to use a 15HP tractor to do a 30hp tractors job. It had 4005 hours on it 8 years ago when it was given to me and the hour meter didn’t work. Kept it maintained but it had seen better days.
I started looking at 40-60HP tractors for FEL and implement capacity, the old Kubota couldn’t pick up 500lbs and barely ran a 4’ finish mower.
It’s been really hard to find anything right now and I missed a tractors locally. I happened to stop by a dealer and there was a shiny new Kioti NX5510HST Cab still on the steel pallet.
I walked in pointed at the tractor and told him I wanted it and to write me a sales quote. Since I had Cat0 and light duty cat 1 implements I also bought any brand implements he had/could get quickly and found some good used ones on Facebook/Craigslist. Unfortunately between NX, an implement, FEL, and ballast that meant a new 14k trailer as well.
Sold the old tractor and 8 implements for enough to buy most of the new implements.
I did a good bit of lurking on here before I did anything thanks for all the good info. I stole goid ideas from several people. I had the dealer order 2 additional rear remotes, rear wiper, but they are on back order. I ordered all the filters for the 50hr service, and 4 extra keys. I added the true 3rd function, added an extra wireless backup camera I have for enclosed trailers, replaced the front halogens with a pair of rough country floods, waiting till I can get a good deal on a matching set for the rear, added the hydraulic top link, waiting on my tilt link, waiting on it to stop pouring down rain to weld on some expanded metal to the grill guard for the grapple, I added a BT radio using the cover plate as a mounting beacket, and a quadlock brand phone holder like I use in the truck and on the SxS to the right side door bar.
I am looking for a good way to keep tools with me considering there’s no real space for tools in the cab and looking for a way to mount my Milwaukee packout cooler somewhere, water y’all not beer on the tractor I’m not George Jones. I’m also looking for a light duty SSQA auger, wrestling a 3point auger is too hard on my back.
As of now I have 66” dual cylinder grapple, 4000# pallet forks, 72” bucket with Piranha bar on order, Dirt Dog 6’ rotary, Alamo 8’ flail, unknown green 7’ finish, Titan 6’ box blade, Dirt Dog 6’ grader blade, unknown 7’ disc with railroad rail for ballast, unknown 3pt auger, and Titan Quick hitch.
With the terrain around our acreage I had them set the tires (R14) as wide as they could be set and ballast them. I wanted 7’ implements so they stuck out 3-4” beyond the tires, and heavier duty but with limited supply I got what I got. There was a nice 7’ ModernAg rotary that was MUCH heavier duty I had ordered but it wouldn’t show until December and I couldn’t wait that long.
So far in 90-95 temps with 105-110+ heat index the cab and AC have been worth EVERY hard earned penny.
In 40hours over the last month my only issues have been an empty front axle (I double checked behind the dealer and manufacturer when I got it home didn’t have fluid at all), a single loose lugnut, a loose water pump/alternator belt, and a misaligned hood latch (looks like it got bent in shipping it had damage when still on the pallet) but I didn’t argue too much since there’s not a lot of inventory.
So far it’s cost me 2gallons of oil for the front axle, dealer was 2.5 hours one way, not worth the fuel to go get the free oil and a new tire on the new trailer after I found a screw to the sidewall.
The new 55HP is light years beyond the tired old 15HP, an FEL that could pick up the old tractor with the FEL and an implement, has been VERY useful moving pines I’ve cut down to make way for the first of two garage/shops, and hardwoods around where the pool is going to go. The grader blade makes quick work shifting all the gravel back into place on our hilly driveway after hard rains, and is going to get some use smoothing/leveling some ground. I have yet to decide if I like the finish better than the flail mower or not, they each have their virtues. I’m leaning towards selling the flail but either is 100x better than the tired old mid-mount mower that bogged in the thick grass or an underpowered ZTR.
Complaints, so far it needs a buzzer or beeper warning for the 2sec seat switch shut down, I have forgotten to put it in Neutral several times and I get my feet on the ground as I hear it shut off. A warning buzzer would remind me to shift it to neutral.
Other than that It’s only got 40hrs on it, and I did my due diligence before I bought it so I knew what to expect
I’ll post an actual finished picture of it later but I’ve been using it not posing for pictures.
For an assembled tractor, Here is a picture of a old HST IH the guy had that I bought the finish mower off of. He was running a 15’ batwing to cut 400acres with it.
/ New member - Upgrade from semi-ancient #3
G'day Mate and welcome to TBN from Downunder.
Congrats on your new rig... "I did a good bit of lurking on here before I did anything thanks for all the good info. I stole good ideas from several people." Nah, all of those good ideas are part of what this site is all about. I can't begin to tell you what I've learnt, and am still learning, from the blokes here. Everyone's got something to contribute.
Enjoy the site.
/ New member - Upgrade from semi-ancient #4
Welcome and congratulations on a nice machine. Keep us updated on your projects with pictures.
/ New member - Upgrade from semi-ancient #5
Sounds like you are experiencing a Major lifestyle change - and reveling in every minute. Con-grads and welcome - checkout the How many implements thread - a dude needs goals! Really glad you are enjoying your new Kioti!!
/ New member - Upgrade from semi-ancient #6
Welcome to the forum, lots of great information here as you've already found out. When I first saw the picture I thought that you must live in a rough area, then realized it probably just hadn't been assembled yet.... ;). Nice looking tractor, look forward to more pictures when you get it all set up.
Enjoy the site.
I help run a power sports forum and as many good ideas as if had I've stolen other peoples. I'll happily give credit where credit is due.
Looks like a small bridge is on the list ahead of finishing the clearing for a shop, my implement storage has been across a wet weather creek and the 2000# Kubota didn't have any issues but the 8500# Kioti is going to cause some. I have a stack of free utility poles so I'll get a HEAVY duty one together PDQ.
Oh yeah a bit like upgrading from a Pinto to a Maserati. I have a few I want to add but I'm good for a bit till I can get the older ones adapted to the QH or I find some steals on Fakebook/CList
y'ain't right
/ New member - Upgrade from semi-ancient #9
If you are building a bridge you may want to check out this thread if you haven't already...
I saw that mine will only be about 20' long, its a narrow wet weather creek that water only gets 8-10" deep but the area gets very soggy and is not suited for 8500# of tractor. Ill end up with it stuck and that's not a day I want to have.
Plan is to set ends of 7-9 poles on a concrete slab in the ground trap them from shifting with poles set in the concrete on either end. Ill set two in concrete in the middle and place a support under the middle. I have access to a sawmill and I will saw some down to 3"-4" thick boards and run perpendicular to poles and lag bolt into them. Will end up being about 10' wide and @20' long. The ground on either end is firm as is the bottom of the creek when it's not full of water.
/ New member - Upgrade from semi-ancient #11
Before you buy a quick hitch check out Pats easy link system - a little slower, but much more versatile and doesn’t crowd the rear of the tractor for hooking up your PTO shaft.
Already have the QH, its not too bad except with the flail since its more tightly packed right at the hitch pins. I prefer not wrestling the arms and adjusting them side to side and in and out to make everything line up. PTO shafts will always make me want to buy multiple tractors and leave everything connected from the day I buy it till I sell it.
/ New member - Upgrade from semi-ancient #13
Welcome.
Nice big tractor. Look forward to more pictures.
I only have a finish mower to hook up a pto shaft but I agree. Greasy hands and skinned knuckles every time.
/ New member - Upgrade from semi-ancient #14
Howdy y'all. First time posting, but i've been learning lots of good things to keep my old tractor alive a bit longer- Thanks for everyone's ideas and advice. I have my order in for a new RX6620. For the same reason. Tired, 40 yr old tractor too small too keep using. Thanks for the info about the comparison between tractors. That's exactly what i needed to convince the wife for the new tractor.
/ New member - Upgrade from semi-ancient #15
Congratulations on your purchase. Looks good even on the pallet with no wheels. My 2018 DK5510 has been problem free for me, mines a shuttle shift but that’s what I wanted. Enjoy your tractor for many years.
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2013 Freightliner CASCADIA DAY CAB (A59575)
2013 Freightliner...
2023 FREIGHTLINER M2 4X2 24FT NON CDL SLEEPER BOX TRUCK (A59906)
2023 FREIGHTLINER...
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
