Backup Camera--Can't See Ball When In Shadow
/ Backup Camera--Can't See Ball When In Shadow #1
npalen
Elite Member
Beloit, KS
Kubota B9200 HSTD and Mahindra 3015
I'm sure many of you folks have experienced the scenario when backing up to attach a trailer: The vehicle is facing toward the sun leaving a shadow over the hitch ball area making it very difficult to see on the monitor.
Wondering if it would be effective replacing the license plate lights with LED's bright enough to remove the shadow? Anyone tried this?
/ Backup Camera--Can't See Ball When In Shadow #2
LED's would probably be better than the stock license plate lights, but I doubt there would enough difference to help much. Maybe spot of something like red paint on top of the hitch ball would help??
/ Backup Camera--Can't See Ball When In Shadow #3
I have the same problem with a gooseneck hitch. I have a black bed liner and a black trailer. I painted white reference points in a few places and a white mark on the tongue. The contrast seems to be the key and works well.
I also have a glare problem when the sun is shining on the lens and haven't figured that one out yet.
/ Backup Camera--Can't See Ball When In Shadow #4
Add a separate light that comes on with the backup lights.
Or get a magnetic battery light. Use it when you need it.
/ Backup Camera--Can't See Ball When In Shadow #5
Put some reflective tape around the shaft near the ball. I expect anything you put ON the ball itself will get wiped off.
I ordered a small LED to mount where one of the license plate lamps is currently and will report back with the results when its installed.
That's a good idea except this camera is custom mounted up above on the tailgate so it wouldn't "see" the reflective tape from that angle. The camera was designed to attach to the license plate mount but its very hard to judge distance especially with wide angle lens at that angle.
/ Backup Camera--Can't See Ball When In Shadow #8
I replaced both of my LPLs with these. They are extremely bright--Even in daylight. My problem is the truck is raised and I usually need a dropped ball. My camera is just below the tailgate so I can't even see the ball. I thought about getting a magnetic mirror to put on a trailer but I'd need someone to help adjust it. I just have him/her guide me instead. :giggle:
I modified my camera and made this adjustable mount to aim down to make it easier to see distance remaining between trailer hitch and the ball when backing. Can be easily adjusted to face to the rear for normal backup and driving.
Still need to paint the bracket and port the cable directly into the tailgate to "dress it up".
Notice the banged up license plate from not having a backup camera previously. :)
/ Backup Camera--Can't See Ball When In Shadow #11
I've used (and posted about here) a $20 Wyze cam with a $13 battery for backup, latest using my phone as a hotspot.
Real easy, take the cam & battery, place it on the bumper (it has a magnetic mount) connect wirelessly with the phone, adjust the camera. Also works as a FEL cam.
Here's an example using it as a trailer back up cam, battery in the bag.
/ Backup Camera--Can't See Ball When In Shadow #12
Cut a piece of aluminum foil about 4-5 inches across. Wrap it over the top of the ball, shiny side up. Back up until the ball is under the coupler. Remove the foil and lower the coupler. Save the foil for the next time.
I found it made a big improvement in hitching visibility when I painted the coupler silver instead of black.
You need to clearly see both the ball and the coupler.
Bruce
/ Backup Camera--Can't See Ball When In Shadow #13
Some great advice here.
I never thought about turning my lights on so the tag light would illuminate the hitch.
I think I will go out and clean my ball and couplers and paint them while it's on my mind.
I bought a new backup camera a while back that has led lights built in. I just haven't swapped it out. They are supposed to be white, not infrared so the night view remains in color. Today may be the day for that too.
EDIT: I got my ball and couplers painted. All I had that was bright was metallic gold. Painting the ball and coupler rims made a huge difference in visibility.
I also got around to installing the new camera I've had sitting for a couple of years. The white LEDs were supposed to make the night image clearer and in color. Instead they wash out the image at night. I am back shopping for a third camera. I am finding they all feed from RCA jacks and that is the only connection in I have so resolution is going to be limited no matter what.
/ Backup Camera--Can't See Ball When In Shadow #15
It should work fine as long as you have a hot spot and can connect to Wyze's mothership. I considered this idea, but many areas (including my home) do not have adequate cellular service. Also, I don't want to add hotspot to my data plan. I'm looking for something equally simple, but peer to peer. Haven't found it yet.
/ Backup Camera--Can't See Ball When In Shadow #16
My phone and plan came automatically with hotspot capability and it only uses a very little bit of data. Just remember to turn it off after your connected.
/ Backup Camera--Can't See Ball When In Shadow #17
A shiny new ball solved the problem for me.
Sorry to say that adding a bright LED next to one of the license plate lamps and shining on the ball did nothing to make the ball visible when in a shadow.
Will try the aluminum foil trick as mentioned by bcp in post #12 above. Also can see where painting the ball and coupler bright would help as others have suggested.
Thanks for all the feedback, guys!
I found the shiny foil on the hitch ball improves visibility greatly on the monitor! Now I need to paint the trailer coupler with a bright color.
/ Backup Camera--Can't See Ball When In Shadow #20
I painted my ball and couplers metallic gold and it helped a lot. When I swapped my rear camera out for one with white LED lights it washes out the distance view at night but does enhance the close up view of the ball and coupler. The camera with white LEDs has a much clearer daytime picture than my old one did. I ordered a couple different cheap cameras to try and see if one is better than another. They all connect to my head unit by RCA so image quality is somewhat regulated by that.
3PT BOG HARROW (A63291)
3PT BOG HARROW...
CASE 610 Sprayer System 2000 Gallons (A63688)
CASE 610 Sprayer...
2021 PETERBILT 388 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2021 PETERBILT 388...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2019 John Deere R-4038 (A61306)
2019 John Deere...
2012 Infiniti QX56 (A61574)
2012 Infiniti QX56...
