nathan1648
- Joined
- Aug 13, 2021
- Messages
- 10
- Tractor
- LS XG3025
I have around 600 hrs on the tractor and over time the 3 point arms started to leak down while tractor is running. At first about every 30 seconds the implement would jump back up and gradually over time its happening every few seconds (after tractor is hot). I can turn the valve under the seat and lock the implement in place and it will not leak down which leads me to believe it could be an adjustment in the control valve for the 3 point. Also, if the tractor is off and the implement is not locked into place it will leak down to the ground in a matter of seconds. The front end loader has plenty of power and does not leak down while tractor is running or shut off- so I don't believe it to be a pump issue. I have done all the fluid/filter changes the manual requires. Any ideas? Thanks
