Chute ideas for Kubota F
/ Chute ideas for Kubota F #21
From Messick's website, here is the plastic discharge chute:
010CHUTE, DISCHARGE- COVER,DISCHARGEK5678-47113$27.059 in stock1
" href="https://www.messicks.com/services/i...jpg&id=0&thumbnail=True&w=0&hideIfEmpty=False" target="_blank" class="text-success" data-original-title="" style="box-sizing: border-box; background: transparent; color: rgb(70, 136, 71); text-decoration: none; font-size: 12pt;">020SPRING, DISCHARG- SPRING(DISCHARGE)K5668-47162$12.607 in stock1
" href="https://www.messicks.com/services/i...jpg&id=0&thumbnail=True&w=0&hideIfEmpty=False" target="_blank" class="text-success" data-original-title="" style="box-sizing: border-box; background: transparent; color: rgb(70, 136, 71); text-decoration: none; font-size: 12pt;">030PIN, DISCHARGE- PIN,DISCHARGEK5668-47152$7.9726 in stock1
040PIN, COTTER PLTD- replaces #75599-53152 PIN,COTTER(3/32*3/4)75599-52115
75599-53152
/ Chute ideas for Kubota F #22
Not for me. After trying a rear discharge in dry grass, I found I prefer blowing the clippings rather as opposed to inhaling them, or wearing them on windy days.
I actually removed the steel chute and I found a plastic Exmark chute to use for now. Will try to find something else better soon.
Been there, I understand what you mean.
It would be pretty simple job to add a full width "mudflap" or 5 - 6" high rubber skirt in the rear edge of rear discharge deck.
I am still working in between 12 hour days and passing out to sleep, but plan to either do a cable controlled flap (if available) or a simple rubber flap.
A rear discharge deck is in the rear view mirror now, so I gotta roll with what I got.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
BE HW4013HG HOT WATER PRESSURE WASHER (A59823)
BE HW4013HG HOT...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
