Big Barn’s Retirement Farm Shop
   / Big Barn’s Retirement Farm Shop #4,791
The idea behind using a smaller cutter on thin material is based on the amount of surface contact you have (diameter contact vs vertical contact). A smaller cutter will cause the material to chatter less than a large cutter. Chattering material will chip your cutter. Yes, you could profile it and drop it out as well. Full width milling can leave a rough finish, just plan for a clean-up pass around it. As good as that full radius looks, you don't really need it. Just use a 1/4" bit and leave the back square. When you don't have coolant flood (like in a CNC machine) you want to slow down spindle speed significantly because stainless generates quite a bit of heat and you don't have enough cooling mass to remove that heat. If you must use stainless, 400 series would be a better choice when milling, as it lacks nickel. I've milled my fair share of tool steel - A2, D2 and 4140PH being the main ones - and I'd rather mill tool steel than 300 series stainless.
My good friend Pat found this ad on Facebook Marketplace...
To which he sent this reply .....
I feel very privileged to have him as a friend.
   / Big Barn’s Retirement Farm Shop #4,793
I hope your friend got a favorable response.
Not certain.
Maybe. Maybe not. Won't matter to him. He's used to controversy.
My friends Dave and Cathy keep their landscape equipment in my yard and in appreciation often surprise me with thoughtful gifts.
They found this cool pump oiler at a garage sale on the weekend..
I prefer the patina look but this one had too many sharp edges.
So I spiffed it up.
   / Big Barn’s Retirement Farm Shop #4,796
Very Spiffy Mr Barn!
   / Big Barn’s Retirement Farm Shop #4,798
Nice long reach
   / Big Barn’s Retirement Farm Shop #4,799
So I spiffed it up.
I like the unspiffy look better but I suppose if one was cutting up their hands with it, then it had to go.
Same here. Especially when I look at before and after.
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
71052 (A49346)
71052 (A49346)
Danuser Digger F-8 (A52128)
Danuser Digger F-8...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
2025 78in Dual Cylinder Hydraulic Grapple Rake Skid Steer Attachment (A50322)
2025 78in Dual...
2012 MACK PINNACLE (A50854)
2012 MACK PINNACLE...
