AC addon
/ AC addon #1
Lloyd J
Kubota mx4700
Hello everyone, first time posting, I built a cab for my MX 4700 and I would like to add ac,has anybody added this?any ideas?suggestions? Thank you
/ AC addon #2
Hello everyone, first time posting, I built a cab for my MX 4700 and I would like to add ac,has anybody added this?any ideas?suggestions? Tha.yep, just get an AC unit
Yep, added several. You can buy units with hydraulic compressors that are self contained. Since its on a tractor. I've put on kits where you make the hoses yourself. They sent me out to Dallas to put one on a 50,000# trac hoe. If you do a regular one, you'll have to put a CONDENSER in front of radiator and run lines all the way to your unit in or on the cab. Self contained units start looking pretty good when you start adding things up. The unit I'm talking about is used on rail road track repair equipment. Just run two hydraulic lines and a hot wire for the fan. Those items can be found at most street corner parts stores. Once I put an international cab on a big Massey Ferguson and used the 68 air unit on the cab. They took it off in 1970 because the air didn't work. She works now.
/ AC addon
Thank you, can you give me product names so I can look them up and see if I can get them in Canada?
LMC Ag 300 Gallon 54' Boom Sprayer (A60462)
LMC Ag 300 Gallon...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
2009 FREIGHTLINER CASCADIA (A60736)
2009 FREIGHTLINER...
2024 Linx 6'x14' Trailer (A60462)
2024 Linx 6'x14'...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
