Does this noise indicate an issue that can cause damage?
/ Does this noise indicate an issue that can cause damage? #1
Blue Mule
Central Kentucky
New Holland Workmaster 40
In a nutshell:
New Holland Workmaster 40. Tractor has 52 hours on it. I bought it with only a few hours (brand new never sold) and the dealership installed a New Holland loader from another new tractor onto this one at time of purchase. I've had it six months now. Since new, it has made this noise with the first start-up of each day. Doesn't matter what the weather is like. Doesn't matter time of day. The first start-up produces this noise. The noise lasts 10 seconds or less, then goes away and doesn't return until the next day. Hydraulic filters have both been changed. Fluid is still clear to honey colored and at the proper level. I see no leaks anywhere. Pressure at the loader cylinders tested at 2,400ish PSI. Everything seems normal, but this noise is pretty loud each morning. Should I be concerned?
/ Does this noise indicate an issue that can cause damage? #2
same tractor, different branding stickers, same problem. Still awaiting resolution.
/ Does this noise indicate an issue that can cause damage? #3
Doesn't sound normal to me. None of my tractors have ever made a sound like that
Andy
/ Does this noise indicate an issue that can cause damage? #4
It sounds like fluid ( most likely hydraulic) momentarily leaking past a seal. Since the sound dissipates so quickly, I wouldn’t worry about it.
I would guess that it is an o-ring that was either twisted upon installation or perhaps slightly cut and it allows leakage until pressure builds up on both sides.
/ Does this noise indicate an issue that can cause damage? #5
That’s quite the battle cry... 😂
Hopefully it’s a simple fix the dealership can remedy quickly!
Thanks! I'm going to jump into that thread and follow his resolution.
1993 East 39' Dump Trailer (A60462)
1993 East 39' Dump...
2014 FREIGHTLINER CASCADIA 125 6X4 T/A MID ROOF SLEEPER TRUCK TRACTOR (A59908)
2014 FREIGHTLINER...
CHALLENGER VACUUM PUMP (A60736)
CHALLENGER VACUUM...
BOX BLADE (A58214)
BOX BLADE (A58214)
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
SKIDDED WASTE WATER FIBERGLASS TANKS (A60736)
SKIDDED WASTE...
