Hydraulic leaking problem
/ Hydraulic leaking problem #1
Cuda1
International 364
I have an international 364 tractor, my question is it has a vented fill plug on the hydraulic system when I am using the tractor fluid pours out the top of it. The manufacturer and local dealer are telling me it should not be vented or does not show it being a vented plug. Why would it have a vented plug and do I need it to be vented? A loader bucket I believe was added to it. It is not original.
Any advice would be appreciated. Thanks
/ Hydraulic leaking problem #2
There has to be a vent somewhere. My guess is someone put in the wrong fill plug and the fill hole happens to be in a spot where oil is getting thrown against it, like maybe by a spinning gear. Ask the dealer/manufacturer where the vent is if it's not supposed to be in the filler plug. Then you can verify that vent is really there, then you can get the right fill plug and it won't leak. Is it possible the system is overfilled? When you say fluid "pours" out, that kind of sounds like it might be overfilled.
/ Hydraulic leaking problem #3
Hello Cuda,
I guess your 364 is a bit newer version of my 354. I have never found a vent for the hydraulic system on my tractor and due to oil leaking I decided to make one. You can see photos of what I came up with in this thread:
Looking for valves for gas 444
As has been stated, if you overfill the system the oil will flow out any vent. Don't ask me how I know!
Hope this helps.
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2020 CATERPILLAR 289D3 SKID STEER (A62129)
2020 CATERPILLAR...
PALLET OF 12IRON GATES (A58214)
PALLET OF 12IRON...
Mini Metal Standing Fire Pit (A61569)
Mini Metal...
2021 KUBOTA SVL95-2S SKID STEER (A62129)
2021 KUBOTA...
(11) HAND SANITIZER STATIONS (A60736)
(11) HAND...
