IndyJay
Super Star Member
- Joined
- Apr 23, 2021
- Messages
- 18,617
- Location
- S.E. Indiana
- Tractor
- 2021 Kioti DK4510MS w/Loader, Grapple Prev: Massey 1250
I just completed the 50 hour service on my DK4510 Manual Shuttle and thought I'd share a few thoughts for others that recently bought this tractor.
First off, the FEL frame and draw bar do not leave much room to get under the tractor, even on a creeper. It is tight but doable.
I bought a small, inexpensive battery operated pump from HF to transfer the Hydro/Trans oil with mixed results.
It worked okay but pumped much slower than advertised and shown on YouTube, probably due to viscosity.
www.harborfreight.com
See related TBN post here: Oil & Fuel - hyd. filter change
I used WIX filters purchased from local Kioti dealer: #51381 - Oil Filter, #WL10113 - Hydr Filter
Was originally going to reuse hydro fluid but didn't like the way it looked so I replaced with TSC Travellers 590901 Premium Universal Fluid
Oil drain plugs 17mm; oil filter wasn't as bad as I had expected. It was tight but easily loosened with a metal strap wrench.
Hydro drain plugs 30mm (or in my case 1-3/16"); tried metal strap wrench from TSC, it folded; tried rubber strap wrench from O'Reillys, it slipped.
Finally went with the Channel Lock 215 filter wrench that I already had but was afraid would crush the filter. Worked like a charm, did not mangle the filter.
I had considered the vacuum cleaner trick or some other way to reuse the oil, but it was worth $39.99 x2 plus the 2 gal pail of oil for peace of mind.
Overall, uneventful, few surprises. The manual says 1.95 gals oil capacity, 2 gals put it about half inch above full mark. (.05 gal is only ~ 6oz)
The oil fill cap is pretty cramped to get to. Figure next time I'll coordinate that with the fuel filter swap so there is more room.
Battery-Operated Liquid Transfer Pump
Amazing deals on this Transfer Pump Battery Operated at Harbor Freight. Quality tools & low prices.
