Batteries! How weird they are...
/ Batteries! How weird they are... #1
Fuddy1952
Elite Member
South Central Virginia
1973 Economy and 2018 John Deere 3038E
Mind blowing...
I have my granddad's Economy Power King tractor he bought brand new and a Cub Cadet garden tractor, both have same Kohler engine and about same vintage (1976,1979).
Economy came with a car battery, by that I mean a top post (12"x8"x7"). For years it's been hard starting, so I installed a new 700CCA battery. Still hard starting (I rebuilt carb, all new ignition, no help). Basically choke...crank, fiddling with throttle finally it will start. Many times out somewhere I'd park so I could get it rolling & pop start it.
Although battery was new, I had it professionally checked, it was good and actually measured 717CCA.
All ground connections cleaned, cables fine, solenoid & starter fine, the charging stator ok, I even replaced the diode/regulator module. Motor wide open I was lucky getting 13 volts at battery.
Cub Cadet has a new mower battery. It's a 300CCA (8"×6"×5"). It starts fantastically, choke and fires right up then choke off.
OK...today my GLOVES came off .
Both tractors haven't been run in a few weeks, so the surface charge was a little low. Here are the measurements at the battery using Fluke meter:
Economy, 700CCA battery:
12.45v static
11.30v cranking
12.70 full throttle (slowly climbing to
about 13v max. after 10 minutes)
Cub, 300 CCA battery:
12.14v static
9.91v cranking
14.20v full throttle
Then I put the little battery in the Power King:
Economy, using the 300CCA battery:
12.17v static
11.12v cranking
14.13v full throttle
With the small battery it starts, runs better. Of course lights are brighter.
I understand now it's more of a match to the charging system. Apparently the more than double cranking amp battery just wasn't able to spin motor over like you would think which doesn't make sense.
Everything has to match. The larger 70's top post car batteries must have been available with about 300CCA. How weird is that?
/ Batteries! How weird they are... #2
What brands and model batteries? Not everything various manufacturer say is true... especially low end brands, if they briefly hit the benchmark they are "in spec".
/ Batteries! How weird they are... #3
That was a very good experiment that proves bigger is not always better. May have to share that with my wife.
/ Batteries! How weird they are... #4
Yeah...... i think something else is going on there. "Match" as you describe does not work like that with batteries for starting. Just as you said, not only does it not make sense, it almost certainly is not the issue.
Charging is another story, and indeed should be "matched." Right off the bat, i wonder if the terminals on both your batteries are the exact same size and shape/profile.
/ Batteries! How weird they are... #5
Battery match is not a science, it will either spin up starter respectably and provide enough voltage for ignition (if is has points and coil ignition). BUT most small engine are magneto...
I use a not to expensive 230 CCA battery to spin up my JD with a 22.5hp 2 cylinder B&S..... Battery issue is not the problem its the carburetor, and usually a shot of carb cleaner eases "dry" starts.... Carb cleaner is less volatile than "starting" fluid and less like to hurt engine... And magneto on B&S only charges battery a something close to 13.2 volts....
Your ignition and hard starting if not fuel may be the magneto output for firing plugs...
Terminals are different. Economy as I said was top post, Cub is not, but installed right and clean using 1/4" bolts...so that didn't matter.
Changing battery solved the problem though! Changing back to large battery the problem reappeared.
What's going on is the stator+diode/regulator system is not able to keep the 700CCA battery charged and running like that voltage is low.
Using 300CCA battery the stator+diode/reg module is matched. It now runs at just over 14 volts, keeping battery charged and since the voltage is a little more cranks better.
I've spent many hours of experimentation and if I were to use large battery in Cub it would act like the Economy over time. Battery is so large I'd have to fabricate some way mounting it. It would crank Cub fine at first, but the Cubs same charging system wouldn't be able to restore that battery. Over time same thing, lower voltage gradually, lower running voltage (dim lights), until hard starting. Higher voltage means faster cranking, hotter spark, brighter lights, etc.
I'm telling all this hoping it may help someone. Over the years I've discovered some things you think would be an improvement like higher CCA battery may have opposite effect.
/ Batteries! How weird they are... #8
Thanks for the info. I never would've thought a bigger battery would give poorer performance, but the charging theory makes sense.
/ Batteries! How weird they are... #9
"Matching" is not the answer to charging a battery.
I'm sorry. It's an innovative idea, but probably incorrect.
There is a minimum size (ampacity) battery required to turn the starter and start the engine. Any larger capacity battery will simply do the same thing for a longer time. "Matching" the charging system to the battery capacity is not real.
Everything you are seeing and measuring could also be due to a large battery that is able to develop cell voltage, but is not able to store much of a charge (amperage) in those cells. A possible cause for that is something in one or more cells is not allowing the plates to use their full area to store charge. The plates may not be properly isolated, there could be uneven sulphation due to how it was stored, or it may simply be one or more cells have a low amount or acidity of electrolyte.
Science starts with the simplest theory that explains the facts. A poorly built battery makes more physical sense than the electrical matching idea.
rScotty
/ Batteries! How weird they are... #10
sounds like the larger is sulfated. you would need a load test, your testing shows the smaller battery trying harder, but may be able to release more amperage.
  • Good Post
Reactions: JWR
/ Batteries! How weird they are... #11
I'm sorry. It's an innovative, but probably incorrect.
rScotty
"Science starts with the simplest theory that explains the facts."
This principle is often referred to as "Occam's Razor"...
/ Batteries! How weird they are... #12
I posted only trying to help. As I said I had the new battery professionally tested. One thing I forgot to mention which eliminates the large battery and science theory is I replaced that with a known good car battery.
Same results! At first it started tractor great so I thought my troubles were over, but nope...same results, a downward spiral of ever slower cranking.
That's why I said in title how weird they are!
Logically the higher cranking amp battery would start better, more capacity, etc. which I'm sure it is.
Reality is the small battery starts Cub so well, now it starts Economy well.
Bottom line is it all has to match apparently, and maybe help someone.
/ Batteries! How weird they are... #14
Sorry No, bigger battery's will start things better and longer, if everything is equal, something is obviously not equal here.
thats like saying a AAA, is better then a AA, its simply not if all things are equal.
/ Batteries! How weird they are... #15
"Matching" a battery is kinda like fools gold.
Idea may look good, but it ain't reality!
  • Good Post
Reactions: JWR
By match I mean it should be as original for application as possible. I'm finding out a 20 amp charging system isn't a match for a high CCA battery.
No different than putting a 1/2 hp pump in a 500 ft deep well.
Again...only trying to help others by my many hours trial & error. I know what works.
/ Batteries! How weird they are... #17
It could be that the higher capacity battery does not have enough run time for the low output charging system to fully charge the battery. Other accessories could be taking away from the charge as well.
But yes, given the proper time and if the battery is in good shape it should eventually charge to full capacity.
I thought that also, but even without any accessories on lights or PTO clutch I can only get 13v max full throttle...usually 12.7-12.8v.
/ Batteries! How weird they are... #19
"Static" volts on a fully charged battery should be around 13.2 V or better.
Could be the larger battery was simply never fully charged. Try giving ti a full charge using an actual battery charger. It will take a lot longer for a large capacity battery that is not fully charged to come up to "normal" voltage just using the charging system on the vehicle. The measured voltage will be lower until it comes up nearer to full charge.
Does seem odd the smaller battery while reading lower in volts while cranking, seemed better. Was the cranking speed noticeably faster with the smaller battery or did it just fire sooner?
/ Batteries! How weird they are... #20
Want battery matching??... Its a joke.... look at you jump box, it has maybe a 12 amp hour capacity (small gel cell battery (non lithium-ion battery)) but it will jump start a big V8 motor... What you don't seem to grasp is a battery will dump all its chemical energy to meet demand until it self destructs....
2015 Mitsubishi Outlander Sport SUV (A61569)
2015 Mitsubishi...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2008 Ford F-150 Ext. Cab Pickup Truck (A61568)
2008 Ford F-150...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
UNUSED WOLVERINE SFI-22-32W 3 PRONG HAYSPEAR (A62130)
UNUSED WOLVERINE...
