Buying Advice Buying a backhoe ?
/ Buying a backhoe ? #21
Buy a full sized used construction BH, use it for several years to do your jobs, then sell it for what you paid for it originally.
Keep your tractor for your tractor needs.
That is reasonable advice, but having a BH always at your convienience is a wonderful thing, particularly as your body ages.
/ Buying a backhoe ? #22
310 is a good digger but a poor loader. There are some trades.
Why do you say that? I miss the loader on my 310 more than I do the backhoe. They’re strong, carry a lot of dirt and move fast. Finish grading isn’t their strong suit but a tractor or CTL can’t touch a backhoe for scooping and moving materials.
/ Buying a backhoe ? #23
If you are buying used very high on your lists of musts needs to be GOOD TIRES.
Not to knock the benefits of good tires, and yes replacement is a large expense, but if someone threw on god shape used tires just to make a machine look good—run away from it not just walk!
Now if the entire used machine has been afforded the maintenance/upkeep—hoses are in good shape, pins are in good condition, axle seals are not leaking and on and on— that would be a machine worth looking at buying. But 1 single item looking good compared to others needing replaced…..
/ Buying a backhoe ? #24
Seems as if backhoes are one of the least liked tractor attachments, per an article on another forum. They are difficult to install and remove, and don’t have the functionality of an excavator, for starters. If you have a lot of backhoe work on a regular basis, you likely need to consider a good used compact excavator.
If you have occasional need for a backhoe, it’s much less expensive to rent one when you need it. Besides, it’s someone else’s problem when it needs repair or maintenance.
I have owned 1 tractor in my life, but operated equipment during my National Guard career and as I have needed to rent. I am now to the point of considering rental vs. ownership of a backhoe. I have approx 100 acres that are always in need of something, so instead of calling the rental office, I think ownership would be cheaper in the long run. The question is " How do I buy a backhoe?" Where do I go? What should I be looking for and when do I turn and run away? A 4n1 bucket and extended reach with a thumb would be the preferred tractor.
Thanks for the advice
/ Buying a backhoe ? #25
So......when I need a backhoe for 30 minutes, I should drive 30 miles to the rental place, to then learn that their rental units are both out.
Of course, I could call first, but they would still be out.....maybe available next week.
So assume my BH task is only 30 minutes?.........I reserve the BH for next week, then rent their trailer, and tow it home.....1/2 day wasted.
Take it back next day (another total 60 miles travel), and another 1/2 day wasted.
Perhaps that would work for you, but certainly not for me.
Most times I use my BH for only an hour or two at any one time.
/ Buying a backhoe ? #26
I’ll be the first to admit a tractor backhoe is terrible compared to a mini excavator. If you want to spend that kind of money definitely get one. But for what they are a tractor backhoe is a very useful tool. There’s a ton of work like virtually everything a homeowner is going to be doing that’s not a big enough job to justify getting better equipment on site and too much work to do with a shovel. Even if the mini x would do the job way better if it’s only an hour job you’d be done before you got the excavator. I have a mini excavator btw. But I did a lot of work with my BH-90.
/ Buying a backhoe ? #27
Can’t seem to understand why a mini excavator is so much better for performance? The hoe part is the same. Just a different drive system attached. Maybe lots of swing but rather anemic at loader phase!
/ Buying a backhoe ? #28
I'm very pleased with my 3 point backhoe attachment. Has paid for itself many times over in rental fees and is still worth what I paid for it 10 years ago. Just one opinion :)
/ Buying a backhoe ? #29
You’d have to run one for a while to understand. My KX040 a 9800 pound machine will dig as much dirt as my 310 Deere would and it’s a 17,000 pound machine. And the full size was a lot better than a tractor hoe. You’re right the mini is useless at being a loader. You have to have 2 machines and that’s the biggest drawback to them.
/ Buying a backhoe ? #30
Always been happy with my (subframe mounted) tractor backhoe for the past 18 years I've owned it.
I can have it on the tractor and ready to go anytime I need it in 10 minutes.
Takes around 5 minutes to remove it.
/ Buying a backhoe ? #31
The maneuverability of the mini-ex is so much better than a BH and it can get into places and positions a BH can not.
for example: dig a trench from one building to the next to run conduit up the side of the building. The mini-ex can dig the entire length because of it's swing, the BH would have to be reversed and then may not be able to be removed (Depending on the width of the trench) until the trench is filled back in. The tracks on the mini-ex allow it to go places and cross areas that a BH can't. note: I'm aware a construction grade BH can cross ditches, but a tractor mount BH isn't quite up to the same capabilities.
Not sure:
1) whether multiple functions (such as curling the bucket and lifting and swing) can be done at the same time. It can on a mid size excavator and can not on a tractor mount BH - only one function at a time.
2) strength of the mini-ex compared with a BH of the same size.
/ Buying a backhoe ? #32
Not sure:
How many cubic feet of material can a mini-ex transfer 300' in one movement?
/ Buying a backhoe ? #33
About 10 yards. My mini excavator and CTL will make my M59 look silly with one operator. If you’ve got 2 people it’s even better yet. The BIG downside to the CTL and mini is you have to have both of them.
/ Buying a backhoe ? #34
About 10 yards. My mini excavator and CTL will make my M59 look silly with one operator. If you’ve got 2 people it’s even better yet. The BIG downside to the CTL and mini is you have to have both of them. View attachment 707844
Yeah.....but my question was.....
How many yards can be moved 300' in one trip by a mini-ex, .... alone!.
No CTL use in the question.
The point being, that a mini-ex cannot efficiently move material beyond boom reach. and a TLB can instead just drive away with the loader bucket full.
I love the picture of your truck "driver"
/ Buying a backhoe ? #35
I wasn’t a fan of a mini x for a long time and if I could only have one machine it wouldn’t be a mini x. But a mini x is amazingly more productive than even a good backhoe. That mini will out perform my M59 by double. And the truck driver loves going to work. If everyone went to work with the same enthusiasm he did the country would be in a lot better place than it is now.
/ Buying a backhoe ? #36
View attachment 707864 I wasn’t a fan of a mini x for a long time and if I could only have one machine it wouldn’t be a mini x. But a mini x is amazingly more productive than even a good backhoe. That mini will out perform my M59 by double. And the truck driver loves going to work. If everyone went to work with the same enthusiasm he did the country would be in a lot better place than it is now.
Our usage differences are the real story.
You use your equipment to generate income!
I am 80 years old (have had a BH for 34 years), but have always just used my equipment for my own play/work.
Big boy toys.
My assistant is a 2yr. old yellow Lab girl named Sadie, filled with enthusiasm also.
/ Buying a backhoe ? #37
purplewave.com
machinerytrader.com
equipementtrader.com
Several worthwhile threads on here about purchasing/owning backhoe's. To my knowledge extendahoe's and thumbs do not mix.
$30k should get you a reasonably workable backhoe.
I am not calling you out. If you have ran one much at all you know what to look for. Others along with myself on here will happy to list a bunch of points to look for.
I'll start with an easy one to miss. A "low hour machine" that doesn't look low hour. At a local auction house I regularly see beat up "low hour machines". Someone just puts in a new hour meter to hide how many hours the machine really has.
FWIW I own and make a living with a Cat 420D, 4x4, cab, heat, air, 4in1, extendahoe.
purplewave.com
machinerytrader.com
I have often wondered how machines that state low hours are able to be passed as such.
Replacement of the hour meter would be the culprit.
carfacts has an awesome tool for managing that kind of an issue with std vehicles… sad they don’t track tractors that way.
I suppose the best way to scam a potential mark would be to put 1500 or 2000 hours on a machine and then replace the hour meter. For folks that use their machines very little, it would take a long time to recoup anything… 10 or more years, and then what do you get? Maybe a 10 to 20% premium on your tractor when you sell it, minus the cost of the hour meter.
I remember when I was looking at buying a used machine, and you’re right, there were lots of really beat up machines with 400 to 1200 hours on them.
It made me wonder about the durability of Kubota machines in general, that if a machine could get this torn up in 1000 hours, did I really want to spend $30k or more on one.
So yes, now that you have filled me in on that kind of less than honest activity, I can see how misleading any kind of equipment that rests its usage on a simple hour meter can be.
Previous to buying new, I had wondered for a fleeting moment about how easy it might be, thinking that Kubota might require a serial number and old hour meter to program in order to protect the consumer over just handing out replacement meters to anyone at any time … for any reason.
So now, after owning a new L3560 HSTC Cab exactly 1 year and 1 week, I can say the I’m just about 5 hours away from my 400 hour service.
The unit still looks new. TheCab is spotless except for some scrapes of the gray paint on the steps, and the internal metal surrounds and pan around the base of the seat.
Externally, the units is the same, and would still be perfect except for the poor handling of the unit when it was in for warranty work at White’s Tractor in Canastota NY.
There are scrapes up and down the door support verticals, some of which were touched up, others that were not, and none of which were ever communicated to me.
All in all, the durability is ok… not fantastic after a year, as a lot of the fit and finish issues are related to poor service practices from the dealer.
/ Buying a backhoe ? #38
I am 80 years old (have had a BH for 34 years), but have always only used my equipment for play.
Big boy toys.
I bought a 14 year old Kubota L48 TLB with only 251 hours.
Are those hours believable?
Yup!
Bought from private party, original owner, now with debilitating Parkinsons.
Except for some fading (I polished that out), the machine looks nearly like new.
All original paint, with outside storage noticeable on some hoses.
I am 80, so if my two boys decide to sell, it will again be sold with unbelievable low hours.
/ Buying a backhoe ? #39
I am far from an authority and I have more questions that answers. A backhoe loader is on by "bucket list" of toys I want to own as I retire. That being said, are you looking for a backhoe loader or a backhoe attachment on a tractor?
I look at Craigslist to "window shop".
I have made a short list of nice to haves and really nice to have:
Really nice to have: Thumb
Nice to have: 4WD, 4 in 1 bucket, heat-AC
/ Buying a backhoe ? #40
Yup!
Depending on physical size, plan on spending $40K+ for a halfway decent piece of used equipment to meet all your criteria.
2002 FREIGHTLINER COLUMBIA DAY CAB (A62613)
2002 FREIGHTLINER...
2012 23ft Chaparral Sunesta Boat with 22ft. T/A Continental Boat Trailer (A61569)
2012 23ft...
KUBOTA KX057-4 EXCAVATOR (A62129)
KUBOTA KX057-4...
UNUSED KJ 23'X22' DBL GARAGE METAL SHED (A62131)
UNUSED KJ 23'X22'...
2018 Towmaster TC-16 10 Ton Tag A Long Trailer (A61568)
2018 Towmaster...
UNUSED WOLVERINE SBM-12-72W 72" HYD SICKLE MOWER (A62131)
UNUSED WOLVERINE...
