Changing tie rods on a L4310 kubota
/ Changing tie rods on a L4310 kubota #1
tractorcrazy
How hard is it to change tie rods .after i get the nut off how do i get them out of there place
/ Changing tie rods on a L4310 kubota #2
Wedge, most parts stores loan them.
best,
ed
/ Changing tie rods on a L4310 kubota #3
We always called the tool a "pickle fork" in the automotive trade. There are a couple different sizes - width between the forks and angle of the wedge but all work the same with a good drilling hammer.
/ Changing tie rods on a L4310 kubota #4
Yes on different sizes. We used to call the one with the larger space between the forks a ball joint wedge and the smaller a tie rod wedge. A roughly 2lbs hammer works well for hitting the drive end. I have had a couple that fit an air hammer, but some yahoo always seem to get in my tool box and hit them a hammer, for some reason they did not hold up to that treatment, I frequently found them broken.
You can usually rent the forks from a parts store.
Some guys always like to hit the joint with a hammer, but you can damage a joint and have to replace more parts.
/ Changing tie rods on a L4310 kubota #5
You can buy an inexpensive set on Amazon for $39.
May not be everyday repair use quality.. but if I had to do the tie rods on my tractor, I'd pick a set up and give it a go...
Thanks for all the replys i appreciat it
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
Echo SRM2620 Gas Trimmer (A60352)
Echo SRM2620 Gas...
2020 HAMM H7I COMPACT LINE SMOOTH DRUM ROLLER (A59823)
2020 HAMM H7I...
2025 72in CLG72 Hydraulic Log Grapple Skid Steer Attachment (A59228)
2025 72in CLG72...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
