Changing tie rods on a L4310 kubota
   / Changing tie rods on a L4310 kubota #1
tractorcrazy
How hard is it to change tie rods .after i get the nut off how do i get them out of there place
   / Changing tie rods on a L4310 kubota #2
Wedge, most parts stores loan them.
best,
ed
   / Changing tie rods on a L4310 kubota #3
We always called the tool a "pickle fork" in the automotive trade. There are a couple different sizes - width between the forks and angle of the wedge but all work the same with a good drilling hammer.
   / Changing tie rods on a L4310 kubota #4
Yes on different sizes. We used to call the one with the larger space between the forks a ball joint wedge and the smaller a tie rod wedge. A roughly 2lbs hammer works well for hitting the drive end. I have had a couple that fit an air hammer, but some yahoo always seem to get in my tool box and hit them a hammer, for some reason they did not hold up to that treatment, I frequently found them broken.
You can usually rent the forks from a parts store.
Some guys always like to hit the joint with a hammer, but you can damage a joint and have to replace more parts.
   / Changing tie rods on a L4310 kubota #5
You can buy an inexpensive set on Amazon for $39.
May not be everyday repair use quality.. but if I had to do the tie rods on my tractor, I'd pick a set up and give it a go...
Thanks for all the replys i appreciat it
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2006 CHEVROLET EXPRESS SERVICE VAN (A52577)
2006 CHEVROLET...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
