Attachment Help Needed!
/ Attachment Help Needed! #1
lastcast
JD and Kubota
Help needed please!
Son in law has a KUBOTA BX1880.
looking for an attachment he can put on his 3 point rear in which he has a trailer ball so he can just back up under the ball and lift trailer up.
What do I need to get him?, also is it a universal attachment or BX1880 specific? Thanks for your help. 👍😊
/ Attachment Help Needed! #2
Any cat 1 implement should work. Tractor supply probably has one which should be suitable for a tractor that size. Don't expect it to move the 30' travel trailer though.
/ Attachment Help Needed! #3
Two main options...
Buy a 3ph drawbar (with the holes, about $20 at TSC) and mount a trailer ball on it..get one of the kits that adds a locking arm on the drawbar that keeps it from spinning....or...
Buy the same basic thing fabricated with a Reese block hitch...
/ Attachment Help Needed! #4
or a clamp-on trailer hitch for the bucket, or drill a hole in the bucket and put a ball of the appropriate size in it. will obviously depend on how much weight is on the trailer and how far he needs to move it.
/ Attachment Help Needed! #5
That seems like a really bad idea for a tractor that has a FEL capacity of ~600lbs at the pins.
/ Attachment Help Needed! #6
Does the BX have position control on the 3PH? I use my smallest CUT (<2k lbs) for hostling trailers. (FEL cap <800 lb) None (car/tractor hauler, 6x10 ramp-gate, etc) have a tongue weight that tips the tractor with LR or blade on the 3PH vs a serious counterweight. Need at least something for using the FEL anyway and the LR stays on 'Red' for grading vs swapping out for a draw-bar.
I drilled two holes in the bucket and bolt the balls to short extensions so trailer tongues don't foul on the lip and I can tip the ball up to line it up to connect when looking over the hood. (Actually have two b'cuz I keep losing one) Two 7/16" bolts to attach. All trailers are hitched to the towing vehicle when loaded or unloaded. Here's the one I could find. (second attempt at pic upload)
/ Attachment Help Needed! #7
Two main options...
If you’ve looked lately they are more like $40 and the stabilizers are 30-50 on Amazon or TSC. For that just buy one like this, ready to go.
EBESTTECH 3 Point 2 Inch Receiver Trailer Hitch H... Amazon.com: EBESTTECH 3 Point 2 Inch Receiver Trailer Hitch Heavy Duty Steel Category 1 Tractor Tow Hitch Drawbar Adapter for Kubota, BX, LM25H, WLM Tractor, NorTrac, Yanmar, Kioti, Cat 5000lbs Capacity: Automotive
4 x 7 utility trailer. Thanks
9008SFL (A64556)
9008SFL (A64556)
2015 CHEVROLET CAPRICE (A66091)
2015 CHEVROLET...
1998 CHEVROLET C7500 (INOPERABLE) (A67714)
1998 CHEVROLET...
2006 Heil DOT 406 Comp Fuel Tanker (A64194)
2006 Heil DOT 406...
BRADLEY MACHINE MINI VAC TRAILER (INOPERABLE) (A67714)
BRADLEY MACHINE...
GMC 2500 (A67714)
GMC 2500 (A67714)
