What do you do with stump once removed?
/ What do you do with stump once removed? #41
You guys beat me to it. Clean it up - set it out on the county road with a For Sale sign. Somebody is bound to come along and steal it.
/ What do you do with stump once removed? #42
I pile them up at your stump dump throw all brush I can on top than light it up...2 maybe 3 good burning all gone.
/ What do you do with stump once removed? #43
My advantage here - just leave the stump. Let Mother Nature take care of it. Otherwise - chip the limbs and have friends come get the tree for firewood.
/ What do you do with stump once removed? #46
Cover it in moter oil, put a tire around it, and light it off on Lenins Birthday (earth day)
/ What do you do with stump once removed? #47
Put the stump IN the boat... take it to a safe spot, then dump it. Don't toss it and try to drag it. If you have a backhoe, put a piece of plywood across a boat corner, set the stump on it, carefully take the boat out to a deep spot, and push it off. If you feel the need, tie a couple rocks to it to ensure it sinks. Over time, it will become waterlogged and won't be an issue.
/ What do you do with stump once removed? #48
So I took out a 12 inch stump the other day and with its roots, that's over two feet in diameter. Moved it to the fire pit but it's taking longer than expected to burn (it's been dead and cut down a few years ago). What do you do with your removed stumps?
Same thing we do with the HUGE amount of trees we've had to cut up since the May, 2018 flood. They've gone either into 3 or 4 or more gullies on the property or along the creek bank where I figure they'll degrade by the next big flood (ones in 2004 and 2018). Otherwise, you'd have to burn or bury them.
/ What do you do with stump once removed? #49
This is what I use! Bought it 5 years ago and use it a lot! Makes quick work of stumps of any size.
Wow, I wish I had one like that lol.
/ What do you do with stump once removed? #51
Make "cookie" tabletops. I sawed these on my sawmill from a pine stump. Fine someone with a mill and make great gifts or sell them.
/ What do you do with stump once removed? #52
Makes good fencing in the back forty
/ What do you do with stump once removed? #53
Try to store it upside down near the brush pile so rain chips away at the dirt rootball. It will usually burn within 3 or 4 bonfires if the rootball eventually gets clean enough.
/ What do you do with stump once removed? #55
One of ours is sitting in the creek overflow area and just rotting. Too large and uneven to do much with it. Have piled other tree parts in various gullies we have, but this one stump is just too big and uneven to do much other than push it around with the FEL.
/ What do you do with stump once removed? #56
Hmm. Get a box big enough for it and put it in it and place on porch. Put appropriate mailing labels, etc. on it. Let porch theves get it.
/ What do you do with stump once removed? #57
Here is what I do with smaller stumps:
.jpg
/ What do you do with stump once removed? #58
I drill a few 1" holes in them before I put them in my burn pit. They burn up a lot faster that way.
/ What do you do with stump once removed? #59
Long ago I burned one of my huge P. pine stumps - in place. It burned for days. Eventually I had a "smoker" about 30 feet away from this stump. The fire had burned down one of the larger roots.
I quit burning stumps. Besides, all my stumps are way out on the property where nobody can see them. And - I have neither the time or patience to dig out a stump on a 30" to 38" pine tree.
/ What do you do with stump once removed? #60
Just push it into the woods and forget about it. Excellent berm foundation material, though.
That's what I generally do, along with fallen branches and other tree trimmings. It'll rot down eventually.
Take it out on the ice. ;)
That's what a lot of conservation clubs do with old Christmas trees.
Wouldn't it be easier to chip old Christmas trees? That's what they do around here.
Stout Buckets XHD 84 Grapple Skid Steer Bucket (A65640)
Stout Buckets XHD...
LANDPRIDE RCR1872 - 6' ROTARY MOWER (A64277)
LANDPRIDE RCR1872...
2020 ISUZU NPR 16FT BOX TRUCK (A59914)
2020 ISUZU NPR...
2020 CATERPILLAR 289D3 SKID STEER (A65053)
2020 CATERPILLAR...
Aluminum Hog (A65583)
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
