What do you do with stump once removed?
/ What do you do with stump once removed? #1
SylvainG
South West, Qc
Kioti LK30
So I took out a 12 inch stump the other day and with its roots, that's over two feet in diameter. Moved it to the fire pit but it's taking longer than expected to burn (it's been dead and cut down a few years ago). What do you do with your removed stumps?
/ What do you do with stump once removed? #3
My son's burn pit has a tuyere, a 6" pipe in a trench extending from the surface to the bottom of the pit. He runs a 5-amp bouncy-house blower as the fan. The forced air makes the fire burn hotter (and cleaner). As I recall, a 2' diameter tree stump with a 6' diameter rootball took around 12 hours to be reduced to about 10" cube.
/ What do you do with stump once removed? #6
Yard art! Can you drop if somewhere for fish habitat?
That reminds me, in the lake, about 100 feet from the shore, there's a cut stump right side up that is just deep enough that a boat propeller can hit it and break a shear pin (happened to my brother in law). I tried to move it by attaching a rope around it and pull it further down the lake but my boat simply turned around it. I wondered what a tree that size (about 16") was doing so far from the shore. Now I know how it got there lol.
I can use my tractor's backhoe to move it to the lake but not sure how to move it further down the lake though. There is enough sand and rocks mixed with the roots that it will probably sink so not sure my boat can drag it further down the lake.
/ What do you do with stump once removed? #9
I have burned them but some places don't allow that for the amount of smoke they produce.
/ What do you do with stump once removed? #11
Take it out on the ice. ;)
That's what a lot of conservation clubs do with old Christmas trees.
/ What do you do with stump once removed? #12
I burn some but I have been stacking the large ones up along the property line.
/ What do you do with stump once removed? #13
You have to get the dirt out for them to burn. A 12” stump you should be able to get pretty much completely clean.
/ What do you do with stump once removed? #14
That's what I do with all of my prunings, leaves, dirt, broken concrete, old Christmas trees, etc. I pile it up along the back of our property and pile leaves over it. We've been here 25 years and there's a 3' berm the width of the property with pokey branches sticking out of it. Keeps neighbor kids from coming into our yard from that direction. Works great.
Wonder how thick the ice is required to be to support a 4000lb tractor with a few hundred pounds stump. Also, many snowmobiles travel on the lake in winter. Try explaining that you hit a tree in the middle of the lake o_O
/ What do you do with stump once removed? #17
I grew up in WI. Driving on the ice was something fun to do while you froze to death. My older brother lives on a deep lake outside of Milwaukee.
That's exacty what they did, park it and let it sink in the spring. They were doing it in the 60s Divers have found old railroad cars, old autos and trucks and 100s of years of human garbage at the bottom.
Out of site, out of mind.
/ What do you do with stump once removed? #18
I have 11 monsters, I made a ring and call it stump henge, a pagan calendar.
Down here they have stump dumps. Builders take them there as a quick and expensive way to dispose of them.
I wonder what happens to them at the stump dump?
/ What do you do with stump once removed? #19
Sit back and watch them decompose!
Toro Z Master Professional 72in Zero Turn Mower (A61572)
Toro Z Master...
2013 Hitachi ZX160LC-5N Hydraulic Excavator (A61572)
2013 Hitachi...
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
Deere 120 (A64119)
Deere 120 (A64119)
2018 LIEBHERR A900C LITRONIC WHEELED EXCAVATOR (A63276)
2018 LIEBHERR...
Caterpillar D9R Tractor Parts and Service Manuals (A63117)
Caterpillar D9R...
