What have you done to your Branson today?
   / What have you done to your Branson today? #871
I was scraping up some wood chips I had used to fill underneath a tree and the FEL loader notified me that it was only attached on one side. Somehow the linchpin had come out and the main pin apparently followed suit. I was lucky enough to have an extra pin and between moving the levers, driving/steering, and using a come-along I was able to re-attach it.
   / What have you done to your Branson today? #874
Wow Bob, glad you got it back on but looks like it was a pain.
   / What have you done to your Branson today? #875
Good that you noticed that before something got damaged! I've yet to remove my loader. Maybe I should cable tie or safety wire the linch pins so they can't fall off.
   / What have you done to your Branson today? #876
Eeek!
I really need to do a better pre-flight checklist, I've definitely gotten complacent.
   / What have you done to your Branson today? #877
Great save Bob! That could easily have been a lot worse and with a lot of damage.
   / What have you done to your Branson today? #878
Resetting it ended up not being too bad. After I got the come-along and the sling it took about 15 minutes. I used the ROPS as the pull point.
Eeek!
Thanks guys. I was lucky that there was no damage and that I was somehow alert enough to actually notice what was happening. I can't imagine how a spring-loaded linchpin could come off but it's good to know that it's possible. Thanks for the suggestions on securing the pins and inspecting each time out. (y)
   / What have you done to your Branson today? #879
Hey Bob,
I'm just curious if you've been removing your FEL before this pin dropped out?
I have to admit I haven't given my loader pins much thought (other than greasing them of course), but I also haven't ever taken my loader off either.
Do you think this was related to maybe taking the loader on and off?
   / What have you done to your Branson today? #880
Hey Bob,
Hey Slim.
I've been tempted to remove the loader when mowing but have never actually done so. As I'm sure you can tell the FEL came off when backscraping at a steep bucket angle however I don't know when the pin was lost.
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A55745)
1981 AZTEC SKINNY...
2001 Blue Bird Commercial Portable Office Bus (A54814)
2001 Blue Bird...
2011 Ford E-350 Passenger Van (A53422)
2011 Ford E-350...
