case 530 manual desperately needed
/ case 530 manual desperately needed #3
This may help you out, until you find a hard copy. Case 530CK - Manuals
Appreciate it guys this will help, iam having issues trying to find ser#'s on this thing as the panel is gone that tag is on, my dash looks different the the other i see, mine has a smaller tach on it ,I believe a non case loader, 4' bucket and the ser# for the trans is right behind the hyd valves and the engine ser# is behind an adapter plate for the loader
/ case 530 manual desperately needed #5
530 Serial Numbers
Location:Serial number plate on tractor instrument panel.
1960:6144001
1961:6162601
1962:8190001
1963:8208001
1964:8229001
1965:8253501
1966:8279001
1967:8306501
1968:8332101
1969:8356251
Good Luck
/ case 530 manual desperately needed #6
The ser. # on my 310B I had was on the cowling ahead of the dash, and was missing too. Case was notorious for changing parts in a production run at certain serial number breaks. Thank goodness some engineer had intuition enough, that at least the parts I needed had a part number either stamped, or cast into it.
I actually purchased it, believing it was a 530, as it had 530 decals on it. I happened to run across the page I listed above for the 530. I didn't realize it was a 310B, until I ran some part numbers found on the tractor, but didn't match the part numbers listed in the parts manual for the 530 through Google, and found certain parts only fit a 310B. At that time, Case actually was using an agricultural tractor, and added the loader and backhoe. Once I discovered that, I went to the Case/IH AG. site, to look for many part numbers.
This link to Case/IH for the 530 AG Utility series tractor may help you find some parts also.https://www.mycnhistore.com/us/en/caseih/tractors/agricultural/under-100-hp/case-ag-utility-tractor-prior-to-sn-8262800/cn/48D06496-EFBE-E111-9FCE-005056875BD6 Just be aware, parts not sold through Case/IH anymore, the part numbers have been deleted, so you may have to depend on the part numbers listed in the parts manual from above, or, if you can find a part number, on anything you may need to replace..
213088 (A64276)
213088 (A64276)
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A65053)
2021 CATERPILLAR...
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
2020 Ford F-150 4x4 Ext. Cab Pickup Truck (A64194)
2020 Ford F-150...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2018 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2018 SolarTech...
