case 530 manual desperately needed
/ case 530 manual desperately needed #3
This may help you out, until you find a hard copy. Case 530CK - Manuals
Appreciate it guys this will help, iam having issues trying to find ser#'s on this thing as the panel is gone that tag is on, my dash looks different the the other i see, mine has a smaller tach on it ,I believe a non case loader, 4' bucket and the ser# for the trans is right behind the hyd valves and the engine ser# is behind an adapter plate for the loader
/ case 530 manual desperately needed #5
530 Serial Numbers
Location:Serial number plate on tractor instrument panel.
1960:6144001
1961:6162601
1962:8190001
1963:8208001
1964:8229001
1965:8253501
1966:8279001
1967:8306501
1968:8332101
1969:8356251
Good Luck
/ case 530 manual desperately needed #6
The ser. # on my 310B I had was on the cowling ahead of the dash, and was missing too. Case was notorious for changing parts in a production run at certain serial number breaks. Thank goodness some engineer had intuition enough, that at least the parts I needed had a part number either stamped, or cast into it.
I actually purchased it, believing it was a 530, as it had 530 decals on it. I happened to run across the page I listed above for the 530. I didn't realize it was a 310B, until I ran some part numbers found on the tractor, but didn't match the part numbers listed in the parts manual for the 530 through Google, and found certain parts only fit a 310B. At that time, Case actually was using an agricultural tractor, and added the loader and backhoe. Once I discovered that, I went to the Case/IH AG. site, to look for many part numbers.
This link to Case/IH for the 530 AG Utility series tractor may help you find some parts also.https://www.mycnhistore.com/us/en/caseih/tractors/agricultural/under-100-hp/case-ag-utility-tractor-prior-to-sn-8262800/cn/48D06496-EFBE-E111-9FCE-005056875BD6 Just be aware, parts not sold through Case/IH anymore, the part numbers have been deleted, so you may have to depend on the part numbers listed in the parts manual from above, or, if you can find a part number, on anything you may need to replace..
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2022 JOHN DEERE 350G LC EXCAVATOR (A65053)
2022 JOHN DEERE...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A67148)
2023 KENWORTH T680...
10ft Fork Extensions (A64553)
10ft Fork...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
