John deere 1640
/ John deere 1640 #1
sauen
John Deere 1640
Recently bought myself a JD 1640 with leaking up the steering column, i have removed the steeringwheel and large nut and when i put the steering wheel on again and try to turn it CCW it wont come out so i can replace those 6 seals in the column, tips as to what i might be doing wrong?
/ John deere 1640 #2
Welcome to TBN
Post some pics of what you are attempting to do, and likely some guidance will be forthcoming from the TBN members.
/ John deere 1640 #3
Welcome to TBN
How many rounds CCW did you turn steering wheel while attempting to disassemble steering components? It takes several rounds. I guess 6 or more rounds is required.
/ John deere 1640
Welcome to TBN
I turned the wheel all the way to the left on the tractor and have attempted to pull CCW to get it off but its just tight, does it need to be set all the way to the right before attempting? Attached picture of the top of the steering column which i want to get out so i can replace them leaky orings
/ John deere 1640 #5
IIRC with large adjusting nut removed the shaft should turn but frt wheels should not turn. How many rounds(CCW) have you turned shaft? IIRC it requires 6+ rounds. One must unthread shaft(item 1) out of rod(item 19)
/ John deere 1640
The wheels turn when i turn the steeringwheel when i put it back on and the large nut is also removed so the wheels still turn when i try to wind it off
/ John deere 1640 #7
Are you positive you're turning steering shaft (CCW) to the left??
/ John deere 1640
Aye, started the tractor up and moved the wheel to the center, still no big nut on but i moved it there, shut it off and i try to move the wheel to the left CCW as you say but it still moves the tires and even if i try really hard it will just move the tires, do i need to open the panel by the gas pedal and disconnect the socalled dog bone?
/ John deere 1640
Provided a little video
/ John deere 1640 #10
If I was going to go to the trouble of disconnecting the dog bone I just proceed with laying the complete valve assembly on a workbench for disassembly.
/ John deere 1640
Aye, was hoping i could get away with just getting it from the top instead of taking the whole thing out
/ John deere 1640 #12
I do not understand the reason you're unable to unscrew shaft out of sleeve.
/ John deere 1640
Was hoping i could get away with just taking it from the top and still in the tractor :cautious:
/ John deere 1640 #14
Maybe you should consider putting a pipe wrench on steering shaft & exert more force than steering wheel can apply.
I'll state again [/quote]I do not understand the reason you're unable to unscrew shaft out of sleeve.[/quote]
/ John deere 1640
I'll state again
[/QUOTE]
I'll try to get some more power on it, Cheers for all your help
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
Engine Stand (A68134)
PORTA POTTY (A67714)
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2013 FORD F-150 (A67714)
2013 FORD F-150...
2016 JAYCO JAY FLIGHT CAMPER (A67714)
2016 JAYCO JAY...
