Towing JD model FB grain drill
/ Towing JD model FB grain drill #1
bnew17
Georgia
2001 JD 5310 w/ 542 FEL
I have a 9ft pull type JD Van Brunt grain drill I will be taking home in the very near future. It has been sitting up for several years under a barn. I am going to grease all fittings and lubricate. The drive back to my house is probably 2-3 miles. Does anyone have any advice or is there anything in particular I need to do to the grain drill before I make the trip home?
/ Towing JD model FB grain drill #2
Pull the wheels (check the tires for rot and pressure) and pull the spindles and make sure they are greased and bearings intact. If on public roads, a SMY reflective triangle is required as is rear flashing amber lights. I use the self contained battery powered LED flashers (amber) ones myself. Magnetic mount, self contained.
Nothing worse that going down the road and having a rotted tire let go or a bearing seize. Under 20 mph always. Farm tools aren't designed to pull at road speed.
I am actually replacing a rotted tire right now on it. That is what has been holding me up on getting it. I have the new tire, just need to put it on. The other tire has recently been replaced.
/ Towing JD model FB grain drill #4
I'd be checking the wheel bearings, farmers overlook them all the time. I always inflate my tires to the maximum rated sidewall pressure too. Fully inflated tires roll much easier.
I am reading where people recommend removing "3 bolts on each hub" to disengage the chain to where only the wheel and bearings turn. Has anyone done this?
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
(2) New 14-17.5 NHS tires on John Deere 6-lug compact tractor rims, Coal Valley, IL (A65640)
(2) New 14-17.5...
2019 RAM LARAMIE 1500 (A65643)
2019 RAM LARAMIE...
207923 (A63290)
207923 (A63290)
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
2020 KENWORTH T680 TANDEM AXLE SLEEPER (A59914)
2020 KENWORTH T680...
