dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,550
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
People often think - mistakenly - that a particular job is just what it is called - "Painting" means laying down paint on a wall, for example. Of course that is always a piece of it, but there are always so many more steps to it in both prep and cleanup that many folks get the wrong idea of what the job/task is about. All that cleaning you are doing is part of the task of staining the floor, it isn't some extra task to do. When you start thinking of those things as part of the job and not something you have to do to get to the actual job, it starts to make more sense and you won't dislike it so much, perhaps. Sure there are always parts of a job that are better/more fun/etc than others, but if you look at it holistically, it starts to make more sense, or at least you can make you peace with it more easily. And yes, many times all those "extra" steps take far more time than the "actual" task at hand. You can "paint" a room in an hour or so, but it might take you 1-2-3 days to check the wall, fill and sand holes, clean any dust off for good adhesion, mask areas that need to be covered and generally get everything ready for a good paint job.
BTW I am amazed your concrete guy said to stain it before framing. That is totally nutso. Imagine that finished floor sitting open to the weather for a couple years, like it would have in your case. Now they will tell you you should wait at least a month for the concrete to reach full cure before staining, but that usually isn't the issue in most jobs as the stain comes later on enough to not matter.
