F2690 quality issues
/ F2690 quality issues #1
ironpen
Gold Member
Montgomery, Alabama
tn75s, tc33d, mc35, gt65, 6640, 3010s, TS110, TS115, TN70, Massey 5470, Kubota F2690
My F2690 now has 700 hours. It is a 2017 (or maybe 2018) model. Thus far I've had to replace the gearbox on the deck this year and recently I have had to replace the water pump on the motor. Also I had to get my mechanic straighten the arms that connects the deck to the body of the mower. I have a New Holland MC 35 that is a 2003 model and I have never had these kinds of problems. Not heavy duty use....just cutting grass on level ground and it is well established and no heavy cutting required. Home and church yards. Is Kubota using inferior raw materials?? This is very disturbing to me. Comments are welcome.
/ F2690 quality issues #2
The mower deck must have been hitting something in order to bend the lift arms - has it been it driven by hired help?
No I am the only driver and no I have not hit anything.
Well it's happened to me. And how about the gear box and water pump?
/ F2690 quality issues #6
It's been my experience that Kubota generally builds quality products. What you are describing is definitely not the norm.
Sorry for the bad luck.
/ F2690 quality issues #7
How about them? Seals can fail. Sometimes before they should, sometimes from external causes. I don't know how or why your water pump or mower gearbox failed but odds are both began with seal failures from undetermined causes. If you don't know, I sure don't.
But I think it's a safe bet your mower lift arms didn't bend because they are under designed.
If you're looking for some kind of argument I'm not your guy.
/ F2690 quality issues #8
After running a commercial Kubota diesel zero turn for 3 years over crap ground (roots, holes, dirt, etc) I am convinced they are very tough machines.
I rebuilt my mower gearbox at 2000 hours. It was about $600. Didn’t think that was anything to complain about.
My gearbox was $1100. I have a mechanic who keeps everything up to snuff and is very good. I have 4 mowers...a 1999, 2003, 1984 in addition to the Kubota and have them meticulously maintained. Also a 100 inch Rhino, 90 inch Woods and a 121 inch Land Pride that are pull behind finishing mowers and other than an occasional spindle have never had such problems. I am wondering if they are using foreign steel in this newer mower??
/ F2690 quality issues #10
I cannot give any insight on early water pump failure. Also I don't see how the lift arms got bent as I routinely step on the step plate on deck to get on my mower even if it is in raised position so I know the arms are very strong. I do have some comments on the gearbox failure. Mine is a F2680 that I purchased used with only 17 hours on it in July 2013. The only repair that I have had to do other than maintenance was to replace the deck spindle bearings on just one spindle. This was right after I bought it at less than 50 hours. I took spindle off and carried to dealer in Clanton, Al and they repaired with new bearings. Mechanic said this was not first instance that he had seen where spindle wasn't greased properly when new. The Kubota operators manual states to replace the gearbox seals every two years which I haven't done but did do Jan 2018 when it had slightly over 600 hours on it. If the gearbox loses the oil you are going to ruin it quickly. Now my main question is why did you have to buy a new gearbox? I removed my gearbox and again carried to dealer for replacement of the seals as it looked like more of a job than my pay grade allows. Unless the gearbox housing is damaged you can rebuild it for far less than $1100. I still have ticket on my repair and it totals $125.22 parts and labor for gearbox seals and bearings. I remember reading where John Thomas had to replace a gearbox but that was totally neglect in my opinion. Another story. It is hard for me to remember to check gearbox oil routinely or daily but I do try to check it when i do oil changes etc. I am coming up on 1000 hours on mine and I have been totally satisfied with it but I would like to see some changes to how you adjust the cutting height. I just measure how far the adjuster supports stick above the housing but would like to be able to quickly change the height from seat similar to a zero turn.
/ F2690 quality issues #11
Quick change of cutting height in F2680 is simple, all you need is a different mower!
I just leave it the same height in F3060 and don't mess with it.
/ F2690 quality issues #12
Maybe start with comparing the lift arms to an older model in the same line? You could also grind some of the steel to check for carbon content? Not sure where to go with this. If you don't like the Kubota just sell it and move to something else.
/ F2690 quality issues #13
Can you describe the gearbox failure?
Broken gears? We’re they blue from heat due to loss of lubricant?
As far as the water pump failure who knows. Everything is prone to failure given enough time and then there are those early failures that just happen (cause unknown) because of a defect.
90cummins
The gear box itself didn't fail...the shaft that comes down onto the pulley failed and wallowed out the big pulley and the little key lock. I bought a new gear box because my dealer's parts dept. said that was the only way to get a replacement....turns out they were FOS...I called Messick's they sent me 2 shafts, 2 pulleys, and 2 of the key locks. My tractor repairman got them put back together easily and I now own 2 working gear boxes. After tax it cost me $1200 instead of $250 to get it fixed. To say I am irritated with the dealer is a massive understatement.
/ F2690 quality issues #15
Come to think of it, my rebuild was $600, but that also included replacing a U-joint on the driveshaft and a couple other maintenance items. The gearboxes can be rebuilt/repaired.
I‘d put Kubota above the middle bar of manufacturers in terms of repair needs. My farm tractors have been outstanding in reliability. There’s a few minor things broken on each one, but they run and get the work done every day, which is what makes me money.
/ F2690 quality issues #16
It's good to have a spare mower deck bevel gearbox in case overhauling is needed in future, that way you will not be in a hurry and can shop around a little!
My 1997 F3060 RD deck bevel gearbox design is lot simpler, and I was able to find an alternative for around $145 online - good thing since Kubota has discontinued that model gearbox.
Here's more details:
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2018 Ford Explorer AWD SUV (A64557)
2018 Ford Explorer...
2012 JOHN DEERE 210G LC EXCAVATOR (A65053)
2012 JOHN DEERE...
12ft T/A Flatbed Utility Trailer (A64553)
12ft T/A Flatbed...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A64553)
2016 Kubota SSV75...
