When in gear, Tractor will not move
/ When in gear, Tractor will not move #1
rhand48
Streetsboro, Ohio
John Deere 5310 (2001 ?)
I replaced a hydraulic line to the bucket of my John Deere Tractor, because it was leaking. When I installed the new one, I started the Tractor, raised the bucket up and down, no problem. But when I placed the trans in gear, it will not move.... ??? Did I miss something?
:confused:
/ When in gear, Tractor will not move #3
Is the engine started and running when you put it in gear. :) Honestly it sounds like it's something simple like that. Did you leave the park brake on etc? I'll give you an example. I recently threw my jacket behind the seat of my JD 4410 compact utility, got on and started it but it wouldn't move at all (ehydro model). The tractor had just been running so I knew it had to be something simple. The simple act of throwing the jacket behind the seat disconnected the plug for the tractor seat safety switch enough so that there was no connection. In less than a minute I was going again. Tell us the model and year of tractor. It's pretty hard to tell you anything if we don't know what you are talking about
It's a 5310. Not sure of the year. It has to be late 90s or early 00s
I have to add Hydraulic fluid. I read that low fluid will affect the transmission. I will also check safety switches. Thanks for the pointers.
Fluid level is full. No obstruction of seat safety switch.. Yesterday, the tractor was running fine. I took the leaking hydraulic hose off and took it to have another made. This morning, I put the new hose on and tried to start the tractor. It started, I put it in gear and..... Nothing. All gears, nothing. PTO runs. Bucket raises and lowers - is functioning fine. What could it be?
Just to be clear, the hydraulic line that I replaced was located down and to the right of the hydraulic filler tube. As your looking at the PTO it would be among a couple others up to the right.
/ When in gear, Tractor will not move #8
Does this trator have a shuttle shift or is it all gears? Does it lake any unusual noises when you push the clutch in? Are there some electrical wires in the area of the hose you replaced? Could you have bumped something in the area of the replaced hydraulic hose?
No, No shuttle shift. gears. no noises, no wires
/ When in gear, Tractor will not move #10
could be stuck in between high and low range or in neutral??? c falcon
/ When in gear, Tractor will not move #11
I am unclear what line you replaced, it sounds like you replaced the line from the SCV. Do you have a part number and I can look it up on JDparts. The seat switch does nothing, but sound an alarm if the PTO is on and you leave the seat. Once started there is no safety switches which keeps you from going. I take it acts the same no matter what range/gear you are in. Here is a link to tractordata, if you look at the bottom left you can match serial number to your tractor. Here is a picture of the hydraulic system. Does the steering still work?
What you replaced should not keep it from moving.
TractorData.com John Deere 5310 tractor information
  • hydrsystem.pdf
Apparently, air got in the system and had to bleed off. I worked the bucket a few times and put it back in gear. It moved. Thanks to all for your help. It appaears all right now.
/ When in gear, Tractor will not move #13
Strange that a gear drive transmission which should only use Hydraulics for lube and cooling failed due to air in a Hydraulic line. If it was an HST, I would have said continue cycling the Hydraulic cylinders to remove air.
Since my last post, I have heard that air in the hydraulic line is a possible cause, it is more likely that it is a faulty cut-off switch under the seat. Thanks for your input.
/ When in gear, Tractor will not move #15
Agreed. Too much dependent on hydraulics. Could it be a safety feature to assure it isnt run low on hyd/trans fluid?
larry
/ When in gear, Tractor will not move #16
We’re is the park brake located at
2019 FREIGHTLINER M2 106 4X2 S/A 26FT  BOX TRUCK (A59912)
2019 FREIGHTLINER...
PackRat Tool Box & Rubbermaid 100 Gal Stock Stank (A64119)
PackRat Tool Box &...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2016 KUBOTA RTV-X900 UTV (A64280)
2016 KUBOTA...
213096 (A64276)
213096 (A64276)
