Lenar 274-1 Starter removal
/ Lenar 274-1 Starter removal #1
Texas Bill
Lenar 274-1
Has anyone had experience removing the starter on the lenar 274-1 without having to pull the hydraulic pump? Any secret sauce or sequencing would be greatly appreciated.
Thanks Texan Bill
/ Lenar 274-1 Starter removal #2
I remember some of them were really tight, I know our new replacement starters are shorter and you do not have to, but the older type you did
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
www.affordabletractorsalesco.com
979-865-4002
Trying again to see if anyone has any secret. I took the hydraulic pump out and that didn't help either. I can get within 1/8 inch putting the starter and hydraulic pump back in and that is as far as I can get without doing something likely destructive. Any ideas? Is there a hydraulic pump that might be slightly smaller that makes this come together better. Is there a way I am not seeing to stage the pump partially and then pump starter in? These two oppose each other too close to get them in and I still don't have a clue. About to hire a tech but heck it likely might take them forever and still not get this done. Any ideas would be mucho appreciated. I may just sell the tractor for parts and keep the loader for another tractor but was hoping to make this work. Thanks texan bill
/ Lenar 274-1 Starter removal #4
Taking the end cover off the starter will likely give you that 1/8" you desire. Would not surprise me that you have to partially disassemble the starter in situ to remove it. Believe me, this is not a new concept.
Well took back cover off and that wasn't the solution either. I am at the point of considering taking the whole starter apart. Not a starter expert. May have to hire this out if I chose to keeping throwing money at this tractor. Just needed to see if it would start. sigh...anyway thanks for the pointer. texan bill
Took front flange off today and that didn't work either.
/ Lenar 274-1 Starter removal #7
I see a pic without the starter. Looks like you finally did it without taking the front of the engine off. o_O
Still have not figured out how to get the new starter in.
/ Lenar 274-1 Starter removal #10
What is the overall length of the new starter ?? Did you get it from us ?? We had some shorter ones, but I think we are out have some more leaving China soon.With the pump tight, you could prob. grind a 1/8" off the back pump plate to get it in
Tommy
Affordable Tractor Sales Co.
979-865-4002
thanks everyone for all your help. I was able to get it on by shaving/grinding 3/16 of the hydraulic pump rear. Now I find I must have a wiring issue since the starter doesn't do anything unless I use a charger. wish I had a wiring diagram. Bought this tractor with wires taken off and alittle rough.
Hey Tommy,
didn't get it from you. I already ordered it when you chimed in. If I knew I could get it from you would have done that. If this thing cranks/starts I will be ordering things to get this up to snuff. Your suggestion worked and got it to drop in. Now I need to figure out the wiring since it doesn't do anything so either I got it wired wrong or I need to do some re-wiring and maybe new switch and fuse block. That thing is gnarly. texan bill
/ Lenar 274-1 Starter removal #12
The wiring is pretty simple, you have the Large Cable/ wire from the battery, the little wire goes on the solenoid, if it does not do anything you may have put it on the wrong small post on the solenoid
Tommy
979-865-4002
I had it all setup right. I put the charger on the new battery and set at 50 amp engine start and that got the starter to engage enough to spin the flywheel. Not sure the starter fully engaged the fly wheel...but engine fired up after a few rounds which was cool after sitting in a former owners pasture for 3 years. I think it has a wiring issue/dead short somewhere like switch. Just notices the switch looks like someone had tried to use a screwdriver to starter in lieu of key. Key wont stay and i bet there is a short in it. Will replace switch, replace fuse block and install starter relay.
There are 2 while wires loose and not sure where they go but suspecting fuse block since two posts are lacking wires and showing previous wire carnage. These are only 2 wires that are not connected but will try to trace them back somewhere.
Since it fired up like it was a new tractor and no smoke I will put some money in this tractor. It also needs:
-hydraulic line from pump to back of tractor has a line that is leaking slightly. strange to see it as a soft line.
-small leak at the steering hydraulic box
-cooling fan was seized. Not sure if it is a clearance issue or water pump
-several hydraulic lines sun roasted on FEL
-Might add ground strap to make sure a good ground.
-do full service on oils and filters
-after all this will look at trying to fix 4wd shaft. it is missing. owner took it out after making a noise. my guess is coupling or pin severed. didnt have the old shaft.
Texan Bill
/ Lenar 274-1 Starter removal #14
Mine would do the same thing, it wouldn’t turn over without a jump pack or jumper cables hooked up. It also would not charge the battery. I just ground the rust and old paint off of the main ground connection on the frame. I’ve had to do it pretty much once a year, but it does take care of the problem.
/ Lenar 274-1 Starter removal #15
If you coat that connection with dielectric grease or spray with battery terminal protector, it wouldn't have to be an annual chore.
/ Lenar 274-1 Starter removal #16
Might be to late answer for you, but if others have the same challenges I posted a picture of my starter on Lenar 254II
I have to change the starter after 16 years (not bad lifetime) and had to remove a nut from the hydraulic pump to fitt the new back in. Took about one hour to remove and refit the starter.
Wolverine TCR-12-48H Skid Steer Trencher  (A62679)
Wolverine...
(1) Texas Built 25' Stand Alone Livestock Panel W/ Swing Gate (A66408)
(1) Texas Built...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
(12) Round Grass Hay Bales (A66408)
(12) Round Grass...
