Lenar 274-1 Starter removal
   / Lenar 274-1 Starter removal #1
Texas Bill
Lenar 274-1
Has anyone had experience removing the starter on the lenar 274-1 without having to pull the hydraulic pump? Any secret sauce or sequencing would be greatly appreciated.
Thanks Texan Bill
   / Lenar 274-1 Starter removal #2
I remember some of them were really tight, I know our new replacement starters are shorter and you do not have to, but the older type you did
Tommy
Affordable Tractor Sales
"Your Jinma Parts Superstore"
www.affordabletractorsalesco.com
979-865-4002
Trying again to see if anyone has any secret. I took the hydraulic pump out and that didn't help either. I can get within 1/8 inch putting the starter and hydraulic pump back in and that is as far as I can get without doing something likely destructive. Any ideas? Is there a hydraulic pump that might be slightly smaller that makes this come together better. Is there a way I am not seeing to stage the pump partially and then pump starter in? These two oppose each other too close to get them in and I still don't have a clue. About to hire a tech but heck it likely might take them forever and still not get this done. Any ideas would be mucho appreciated. I may just sell the tractor for parts and keep the loader for another tractor but was hoping to make this work. Thanks texan bill
   / Lenar 274-1 Starter removal #4
Taking the end cover off the starter will likely give you that 1/8" you desire. Would not surprise me that you have to partially disassemble the starter in situ to remove it. Believe me, this is not a new concept.
Well took back cover off and that wasn't the solution either. I am at the point of considering taking the whole starter apart. Not a starter expert. May have to hire this out if I chose to keeping throwing money at this tractor. Just needed to see if it would start. sigh...anyway thanks for the pointer. texan bill
Took front flange off today and that didn't work either.
   / Lenar 274-1 Starter removal #7
I see a pic without the starter. Looks like you finally did it without taking the front of the engine off. o_O
Still have not figured out how to get the new starter in.
   / Lenar 274-1 Starter removal #10
What is the overall length of the new starter ?? Did you get it from us ?? We had some shorter ones, but I think we are out have some more leaving China soon.With the pump tight, you could prob. grind a 1/8" off the back pump plate to get it in
Tommy
Affordable Tractor Sales Co.
979-865-4002
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
UNUSED LANDHONOR FW-13-15000G HYD CABLE WINCH (A54757)
UNUSED LANDHONOR...
2025 Wabash 450 Gallon Skid Mounted Vacuum Tank (A52377)
2025 Wabash 450...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2008 JLG 800S TELESCOPIC MANLIFT (A52705)
2008 JLG 800S...
