Do All Their Engines Rattle?
/ Do All Their Engines Rattle? #1
Username Taken
S Florida Winter/Michigan Summer
Kioti CX2510 HST
What do you think it is? Piston slap?
I just watched a video and the engine sounded kinda rough. You can't tell in a video but it made me want to open the hood and look for loose shields or something.
Then I read in the remarks that they all rattle like that, even the Kioti. If that is so, is it piston slap? That's a llot of piston slap if it is.
/ Do All Their Engines Rattle? #2
edit:
We have a Bobcat T250 in the family and it is smooth and quiet- It has a few thousand hour kubota in it another Bobcat in the family a 70 HP mini excavator was a rental machine before bought at auction-but actually built by komatsu also smooth with over 5000 hours on the engine and virtually no low speed or idle knock.
I thought you were asking about their Bobcat (skid steers) Sorry
After watching the video
yeah the new Kioti (Daedong) powered Bobcat tractor sounds like the ones we test drove last year at the Kioti dealer
The engines in the new Bob Tractors are Daedong, same as Kioti. It sounded pretty ratty when he started it. Commenters were saying it was normal.
If that's normal......... I don't know what to think. I'm wondering if it isn't some of the Loader Stand slapping around a little bit. I could live with that, I'd just tie it off or bungee cord it. If it's piston slap...... Not so sure.
/ Do All Their Engines Rattle? #4
Would you care to share the video with us so we can have a better idea of the sound/rattle in question?
"That engine clatter is typical for the small Daedong engines (at least the ones i've owned) . Not sure why. Seems to quiet down a little when warm but not much. Didnt seem to hurt engine life of mine but sure was hard on the ears. Always made me wonder. Owned a 30 hp and a 35 hp and both sounded just like the one in this video."
From the comments section.
/ Do All Their Engines Rattle? #7
Sounds normal to me on a cold diesel engine, however the mic does pick a lot of the noise and makes it sound worse.
Mine does it too but not that much, although I don't really go past 1500 RPMs without the temp gauge start climbing, but mine is a gear tractor, so it doesn't need all the RPMs in the world to keep the HST happy. It goes away once the engine gets up to temp.
/ Do All Their Engines Rattle? #9
My ROPS pins rattle louder than the engine! Haven't bothered to shim them tight yet. Engine really only rattles for a few seconds after startup when cold.
/ Do All Their Engines Rattle? #10
Mine doesn't sound like that in person. Pretty quite to tell the truth. 35hp though.
/ Do All Their Engines Rattle? #11
I was told that it's the engine design that creates the knock/rattle. The fuel is injected into a "pre-combustion chamber" in the cylinder head as opposed to directly into the cylinders as typically done in other designs. Why that produces the noise, I've no idea
/ Do All Their Engines Rattle? #12
My son bought a new 2020 CT2025 and the engine doesn't rattle at all. The only noise on the entire unit comes from the ROPS pins and mostly from the bucket level indicator. He hasn't gotten around to shimming either of them to quiet it down.
He is the Parts Manager for the local Bobcat dealership. He did a lot of research and talking to the salesmen and technicians before he made the purchase. They all had good things to say about the 2000-series and up (stay away from the 1000-series; those are junk!) These are still made by Kioti but are night-and-day over the "original" ones that were released a few years ago.
/ Do All Their Engines Rattle? #13
YES! Same here!
/ Do All Their Engines Rattle? #14
The only time my 2040 rattles like that is when I'm going up a very steep switchback section in my backyard. It happens for about 3 seconds and smooths out as I come over the top.
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
DooLittle XTM-8418 Trailer (A66285)
DooLittle XTM-8418...
1987 FORD F-8000 ROLLBACK TRUCK (A64277)
1987 FORD F-8000...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
