towing a 3039h
/ towing a 3039h #1
clan de boye
clandeboye mb
ls 3039h
I have a 3039h dead in the field with a fuel delivery (i think) issue. Local tow trucks/flat bed won't take a chance on getting out there even though I can drive on the cultivated soil with my f150. I have checked the manual but I couldn't find information on towing a hydrostatic drive tractor. If i have the selector in N would I be okay to tow it with my truck for about 300 yards to a location where the flat bed can load it? Thanks for any advice.
/ towing a 3039h #2
I believe if your machine has a neutral it is ok to tow the tractor short distances while the gear is in neutral.
I think you will be ok.
Good luck and stay safe.
MoKelly
/ towing a 3039h #3
If you have 4WD be sure to disengage it You only want 2WD to be safe. . Then Neutral as mentioned.
2010 MACK CXU TRI-AXLE (A65643)
2010 MACK CXU...
211297 (A62131)
211297 (A62131)
CHEVY DUALLY TRUCK BED (A65643)
CHEVY DUALLY TRUCK...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
2018 Ford F-150 4X4 (A62679)
2018 Ford F-150...
1991 CAT 3406 Generator Set 400KVA/320KW, 480V 3-phase, 60Hz, Industrial Standby (A63689)
1991 CAT 3406...
