lineman1954
peace of mind..flush block, radiator, change thermostat......check oil for any contaminants ( head gasket )
I had the same issue with our 2006 Grasshopper 428D. Creeping water temp. After all the work that’s been suggested here and I can only assume it’s one of those answers ?I’ve got a grasshopper ZT with a Kubota diesel in it. It happens fairly slowly but the temp keeps creeping up. The radiator is clean. The air filter is clean, the fan belt is tight, the fan shroud is in place all but a little bit at the bottom which I don’t think has ever been there. There’s no fan clutch, it’s direct mounted. I’ve taken the thermostat out and ran without it and there’s no change. I put the thermostat in a pot of water and heated it on the stove and the pot was very near boiling before it opened. I honestly thought it would fix the problem taking that out but it didn’t. I might repeat that that test with a thermometer since it was supposed to open at 160 degrees. I’ve taken the side panels and hood off to see if better ventilation would help and it does but not a notable amount. And it blows more heat down my back that way. The radiator is as hot as the block when checked with an infrared thermometer. So it seems to me the radiator is taking heat but not loosing it. I’m pretty much at a loss on this one.
That is a fact. Nothing beats water.Actually, distilled water has the best heat transfer ratio of anything. AF is only needed when the ambient drops below 32 degrees (F).
Replace the sending unit. It's cheap and quick.I’ve got a grasshopper ZT with a Kubota diesel in it. It happens fairly slowly but the temp keeps creeping up. The radiator is clean. The air filter is clean, the fan belt is tight, the fan shroud is in place all but a little bit at the bottom which I don’t think has ever been there. There’s no fan clutch, it’s direct mounted. I’ve taken the thermostat out and ran without it and there’s no change. I put the thermostat in a pot of water and heated it on the stove and the pot was very near boiling before it opened. I honestly thought it would fix the problem taking that out but it didn’t. I might repeat that that test with a thermometer since it was supposed to open at 160 degrees. I’ve taken the side panels and hood off to see if better ventilation would help and it does but not a notable amount. And it blows more heat down my back that way. The radiator is as hot as the block when checked with an infrared thermometer. So it seems to me the radiator is taking heat but not loosing it. I’m pretty much at a loss on this one.
I premix/label for my climate at 50/50 with distilled water that I buy and use weekly along with drinking water and for $.89/gal. Reading labels for yrs it's stuck in my head that 33%-66% is recommended. 33% AF for warm climates, and I've read somewhere that 66% AF may be indicated for diesels to minimize cavitation an/or cyl liner wear where applicable.
I also use a refractometer to gauge acidity. Remember when the service station guy would use one before recommending a change? ('50s, '60s) Modern AFs (yellow/green, orange, 'gold') are typically formulated to protect alum components in car/truck engines from galvanic corrosion. The more noble alum will scale or corrode as coolant ages. A tractor that has no alum head, block, lower intake man, water pump, etc getting coolant flow can do ok with the old green stuff.
I can't imagine a cooling system being so fussy about the exact mix to do its job well. That said it's not just the fins that can need cleaning. Got aluminum radiator? It could be scaled up on the inside. I agree with suggestions that a flush may be needed based on hours & age.
Were you using an aluminum coolant additive (some ford trucks and other specialized vehicles require it)?Yes it’s an aluminum radiator. Even before the overheating issues started its always been fussy about dirt in radiator. My tractor would work fine half buried in chaff but this would start gaining heat with 5 pieces of grass over the radiator.
This is something you may or may have not checked. My sis-n-law had a Kubota lawn tractor with the 3 cylinder diesel that was doing the exact same thing. I finally discovered that there is a screen in front of the radiator that is not real obvious to the eye. It's purpose is to catch debris before it can get to the radiator core and plug it. It lifts up out of the way. Hers was cover with old grass and stuff which inhibited the flow of air. Cleaned it off and viola, no more heating problem.I’ve got a grasshopper ZT with a Kubota diesel in it. It happens fairly slowly but the temp keeps creeping up. The radiator is clean. The air filter is clean, the fan belt is tight, the fan shroud is in place all but a little bit at the bottom which I don’t think has ever been there. There’s no fan clutch, it’s direct mounted. I’ve taken the thermostat out and ran without it and there’s no change. I put the thermostat in a pot of water and heated it on the stove and the pot was very near boiling before it opened. I honestly thought it would fix the problem taking that out but it didn’t. I might repeat that that test with a thermometer since it was supposed to open at 160 degrees. I’ve taken the side panels and hood off to see if better ventilation would help and it does but not a notable amount. And it blows more heat down my back that way. The radiator is as hot as the block when checked with an infrared thermometer. So it seems to me the radiator is taking heat but not loosing it. I’m pretty much at a loss on this one.
There are many, it is a generic industrial engine. Measure it and look it up.Maybe there are cheaper replacement options, but the Grasshopper replacement is over $600.
Water cools better but the antifreeze mixfights corrosion. It does get old. If your tractor has 2600 hours on it the additives are likely gone.I’ve got a grasshopper ZT with a Kubota diesel in it. It happens fairly slowly but the temp keeps creeping up. The radiator is clean. The air filter is clean, the fan belt is tight, the fan shroud is in place all but a little bit at the bottom which I don’t think has ever been there. There’s no fan clutch, it’s direct mounted. I’ve taken the thermostat out and ran without it and there’s no change. I put the thermostat in a pot of water and heated it on the stove and the pot was very near boiling before it opened. I honestly thought it would fix the problem taking that out but it didn’t. I might repeat that that test with a thermometer since it was supposed to open at 160 degrees. I’ve taken the side panels and hood off to see if better ventilation would help and it does but not a notable amount. And it blows more heat down my back that way. The radiator is as hot as the block when checked with an infrared thermometer. So it seems to me the radiator is taking heat but not loosing it. I’m pretty much at a loss on this one.
