Mowing Kubota diesel overheating.
/ Kubota diesel overheating.
/ Kubota diesel overheating. #22
Well this might not be the by the book method to flush a cooling system but it looks pretty flushed and confirmed the water pump is working.
Nothing wrong with a straight water flush.
/ Kubota diesel overheating. #23
In hot weather, antifreeze keeps the water in your engine and radiator from boiling over and in cold
weather keeps it from freezing
JUST PLAIN FACTS!!!
willy
/ Kubota diesel overheating. #24
JUST PLAIN FACTS!!!
willy
I am not sure I agree with your statement in full. While it does prevent freezing, the boiling over is typically done using increases in pressure, which raises the boiling point. Antifreeze keeps it from freezing and has additives which reduce the corrosive properties of pure water. Most antifreeze actually reduces the disbursement of heat, in a minor amount over distilled water, which was what I have been taught, and is easy enough to check.
My thoughts about the original issue, was very similar with a Ford 1100 subcompact I own. It had a creeping temp, and I used a water hose to bring it back down, and it would eventually climb back up when I was working it hard on a hot day. It turned out to be very small particles that had gotten trapped deep inside the radiator which did not allow for a good heat exchange. I had washed the radiator out numerous times, using a water hose which flowed very well thru the fins. I finally removed the radiator and pressure washed it using pressure (be carefull not to damage the fins/tubes). The amount of foreign material that came out was unreal, and I had no clue that it was there. For some reason, I don't remember that there being light capabilities which should have told me that there was foreign material lodged in the fins.
Another thought, in this line of thought was a 1979 Chevy Chevette that my Wife got new as a high school student. She kept that car a lot longer than I wanted her to, but that is another story. The thermostat was sticking and because we were on a trip with time constraints, I simply pulled the thermostat and replaced the housing. If my Wife drove the car, it would overheat in a hurry, while the slightly more aggressive driver would be able to drive a considerable further distance before it overheated. We spent all of our extra time cooling the car down, which made for even tighter time constraints, so replacing the thermostat was put off until we got back. As soon as I replaced the thermostat, the problem went away. Seems the water was going thru the radiator too fast to be able to cool completely and it would slowly build up the temperature till it overheated.
Make sure the thermostat is opening AND CLOSING at the correct temps, and do a really good job of cleaning the accumulated crud out of the fins.
David from jax
I just finished mowing about 2 acres with the straight water in the radiator and it didn’t overheat. The gauge stayed in the middle of the range. Checked with my ir thermometer the block is about 210 degrees and the radiator is 190.
/ Kubota diesel overheating. #26
In hot weather, antifreeze keeps the water in your engine and radiator from boiling over...
JUST PLAIN FACTS!!!
willy
Nope:
"Note! The specific heat of ethylene glycol based water solutions are less than the specific heat of clean water. For a heat transfer system with ethylene glycol the circulated volume must be increased compared to a system only with water.
In a 50% solution with operational temperatures above 36 oF the specific heat capacity is decreased with approximately 20%. The reduced heat capacity must be compensated by circulating more fluid.
Note! The density of ethylene glycol is higher than water - check the specific gravity (SG) table above, so the net impact on the heat transport capacity is reduced. Example - the specific heat of an ethylene glycol water solution 50% / 50% is 0.815 at 80 oF (26.7 oC). Specific gravity at the same conditions is 1.077. The net impact can be estimated to 0.815 * 1.077 = 0.877."
______
"The specific heat capacity of ethylene glycolbased water solutions is less than that of pure water; in a 50 percent solution, ethylene glycol's specific heat capacity compared with pure water is decreased at least 20 percent at 36 degrees and about 17 percent at 200 degrees. Propylene glycol, another common coolant, has an even lower specific heat. Assuming a 100-gpm (gallons/minute) coolant flow rate and an energy loss through the coolant system of 189.5 hp, the water temperature increase would be 10 degrees, the ethylene glycol water mix would gain 20 degrees, and propylene glycol would gain 33.3 degrees.
Compensating for the reduced heat capacity of coolant/water mixes would require circulating more fluid through the system. Assuming a fixed amount of circulating fluid and radiator capacity, running 100 percent water would be the most efficient coolant in terms of its ability to conduct heat with minimal temperature rise. In other words, of all common liquids, water requires the most heat energy to change its temperature.
However, there are also differences in the vapor point of the three different coolants. Ethylene glycol and propylene glycol have higher vapor points and therefore can absorb heat at higher temperatures without boiling. Yet even with its lower vapor point, water still carries more heat per unit."
_____
And so on....
/ Kubota diesel overheating. #27
Coolant doesn't go through the radiator too fast w/o a thermo'. (just too much flow to/thru it.) Lingering myth. A thermostat is also a restrictor/diverter to keep flow going through the engine block uniformly vs just dumped into the rad. A temp gauge won't tell you when top end is running hot from lack of flow when coolant doesn't circulate there as intended. That's why a thermostat's full opening is so much smaller it's bore. If the temp sensor was in the top end the variation would be more apparent, but it's usually not.
Racers use a 'washer' in place of a thermo to maintain coolant proportion between the whole engine and radiator. Without similar and proper coolant distribution the radiator is only cooling the block, not the top end too.
/ Kubota diesel overheating. #28
Would still do a chemical flush then pull the radiator and do a proper cleaning of the fins. You *might* be able to use something like radiator cleaning foam, or acid, without pulling it, but I would just pull it to be certain.
And please do put a thermostat back in. More efficient that way as it not only allows faster warming, but also regulates the water in the block allowing it to absorb as much heat as it can. Especially from around the top of the cylinders and head.
/ Kubota diesel overheating. #31
Do you have the right mix? water alone will
not work and anti-freeze needs water to work
willt
No, it don't Just went through that on another thread. Ordinary distilled water is the best heat transfer medium there is, much better than antifreeze in any concentration. The ONLY thing AF is good for is below freezing temps. Far as corrosion goes, add a bottle of Purple Ice or Water Wetter to the water. That gives it corrosion protection. That will cover the infamous water pump seal that don't exist any more too.
As a side note, race car drivers don't use AF at all, just plain distilled water with Purple Ice or Water Wetter.
Don't believe me, Goggle it up and find out for yourself.
/ Kubota diesel overheating. #32
JUST PLAIN FACTS!!!
willy
1/2 wrong and 1/2 right. AF lowers the freeze point but your rad cap raises the boiling point of the coolant, why the system is pressurized in the first place.
The OP may have a defective rad cap as well. Cheap Kubota part.
So straight water without a thermostat = no over heating? What does that tell you?
I don’t think removing the thermostat helped anything, possibly made it worse. I’ll put one back in but I couldn’t get one over the weekend. My old one probably wasn’t bad but they’re not expensive. And the straight water can’t stay either since it gets below freezing here.
/ Kubota diesel overheating. #34
I bought my Case/IH with a bum thermo'. I could tell right away by the gauge that it wasn't coming up to temp. (Man, was that oil dirty when I changed it the first time.) Anyway, opening temp won't matter if we're overheating. IMO that's kind of a lot of hours on a radiator, even if properly filled/monitored it's entire service life.
/ Kubota diesel overheating. #35
I’ve got a grasshopper ZT with a Kubota diesel in it. It happens fairly slowly but the temp keeps creeping up. The radiator is clean. The air filter is clean, the fan belt is tight, the fan shroud is in place all but a little bit at the bottom which I don’t think has ever been there. There’s no fan clutch, it’s direct mounted. I’ve taken the thermostat out and ran without it and there’s no change. I put the thermostat in a pot of water and heated it on the stove and the pot was very near boiling before it opened. I honestly thought it would fix the problem taking that out but it didn’t. I might repeat that that test with a thermometer since it was supposed to open at 160 degrees. I’ve taken the side panels and hood off to see if better ventilation would help and it does but not a notable amount. And it blows more heat down my back that way. The radiator is as hot as the block when checked with an infrared thermometer. So it seems to me the radiator is taking heat but not loosing it. I’m pretty much at a loss on this one.
Have you deep cleaned the rad fins with a strong stream of water? Whenever one of my tractors temps won’t decrease after pressurized air cleaning, I know it’s time for a strong water rinse.
/ Kubota diesel overheating. #36
I would pull the radiator and clean the fin area so you can see through all of it.
If the water pump is working, apparently, the radiator is not getting rid of the heat.
Yes I’ve washed it with a water hose and from a distance with a gentle pressure washer nozzle.
/ Kubota diesel overheating. #38
If you really need AF, go with the 50-50 pre mix. They use pruified water when they mix it. I use Prestone green myself. In fact Kubota specs green (old style coolant).
/ Kubota diesel overheating. #39
I premix/label for my climate at 50/50 with distilled water that I buy and use weekly along with drinking water and for $.89/gal. Reading labels for yrs it's stuck in my head that 33%-66% is recommended. 33% AF for warm climates, and I've read somewhere that 66% AF may be indicated for diesels to minimize cavitation an/or cyl liner wear where applicable.
I also use a refractometer to gauge acidity. Remember when the service station guy would use one before recommending a change? ('50s, '60s) Modern AFs (yellow/green, orange, 'gold') are typically formulated to protect alum components in car/truck engines from galvanic corrosion. The more noble alum will scale or corrode as coolant ages. A tractor that has no alum head, block, lower intake man, water pump, etc getting coolant flow can do ok with the old green stuff.
I can't imagine a cooling system being so fussy about the exact mix to do its job well. That said it's not just the fins that can need cleaning. Got aluminum radiator? It could be scaled up on the inside. I agree with suggestions that a flush may be needed based on hours & age.
/ Kubota diesel overheating. #40
Put the proper thermostat in it. Take the radiator to a radiator shop and tell them to rod it out. They will take the tank off one end and run a rod downs through every flu. Probably has 2-3 stopped up. That’s all it takes. Then proper coolant mix. Make sure they rod it out not just flush. That should fix it.
2017 Bad Boy Outlaw XP 60in. Zero Turn Commercial Mower (A64553)
2017 Bad Boy...
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2022 EZ-GO ELITE...
International 574 Loader Tractor (A66285)
International 574...
(30) 3"x9' Steel Posts (A66408)
(30) 3"x9' Steel...
New Holland Super Hayliner 68 - Small Square Baler (A66408)
New Holland Super...
