What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today?
Brought it back from the tractor doctor.
Not an entirely uneventful trip.
   / What did you do on or to your LS Tractor today? #1,842
Mowed about 10 acres with my 917 flail, limbed up a bunch of pine trees do I could easily mow under them-used grapple to move limb piles so that I can chip them up later. Also hooked up the tiller for the first time and tilled a serenity garden area for my wife.
This was actually over the last couple of days!
   / What did you do on or to your LS Tractor today? #1,843
I tell ya, this whole making videos for YT is starting to suck... Might be time to simply hang it all up. Really disappointing.
Don’t quit. If it was easy everyone would do it and you’d get the silver play button the day you start. Have you ever gone back and looked at most of the popular channel’s “early work?” Cringeworthy! Lol
   / What did you do on or to your LS Tractor today? #1,844
Just published, an update announcement video and Hooks and Balls Quick Hitch.
Thank you for the words of encouragement. Honestly, it was these words that motivated me to get out and get it done. Thank you.
   / What did you do on or to your LS Tractor today? #1,845
I think you will enjoy the hooks.
One of my reasons is that a standard quick hitch took up to much room when I was having to reach in and connect a pto shaft.
I did break down just the other day and order one of the hydraulic hook type top links to use instead of my regular hydraulic top link.
   / What did you do on or to your LS Tractor today? #1,846
Good job on the video.
I'd just love to have telescoping lower arms! I think If I had those I wouldn't bother changing anything. Like you said, you have to connect hoses and/or PTO shafts so you're down there anyway. Now if you just had multiple implements that were just 3pt connections only, I could see the benefit of these.
I've seen a few posts where the telescoping arms from other models that will work are about $600 a set, maybe someday.
   / What did you do on or to your LS Tractor today? #1,847
I'll play! Who doesn't like a video?
   / What did you do on or to your LS Tractor today? #1,848
I have the speeco E hitch quick hitch. I love this hitch because it does not need bushings. It takes longer to attach the PTO shaft that to latch onto my bushhogs!
   / What did you do on or to your LS Tractor today? #1,849
Moved some blocks to top our new fire pit and moved in some nice sections of tree trunks to sit on. Plus got to burn up some nasty rotten wood.
   / What did you do on or to your LS Tractor today? #1,850
I haven't raked hay in 35 years but it was in MO. with a IH 464 and a New Holland 256 or 258 rake IIRC.
We just use 2 IH 464's and 2 IH 1300 sickle bar mowers. Let it dry 1-3 days then rake it, let it dry 1/2-1 days and then bale it.
Is the hay tedder just to help air out and dry the hay?
Was the hay cut with a mower conditioner or just a sickle bar/ or disc mower?
   / What did you do on or to your LS Tractor today? #1,851
Yes, the Tedder fluffs the hay and helps really speed the drying process. We use a NH 472 mower/conditioner.
That hay was cut and baled in 24 hours. Had a high chance of rain catch up to us. Luckily we got it all up before the storm. Hay was about 95% dry when we baled it.
   / What did you do on or to your LS Tractor today? #1,852
I remember some years like that, we would only mow what we thought was about 500-600 bales (small square ones, about 70-80lbs) then the next day rake that and mow another 500-600 just in case it rained it wouldn't all be ruined before we got it in the barn. Over 13 years I think we only ever lost about 200 bales.
I also remember a few years it was so hot and dry we mowed early morning then seemed like raked and baled that evening or maybe it was the next day, I just know it was faster than usual.
   / What did you do on or to your LS Tractor today? #1,853
Blew the valve in the FEL....grabbed a bucket of base....fanned it out gong in reverse....rolled forward after empty...put a 45 degree angle on the blade...put the loader into float and floated in reverse....looked up and my dash was covered with fluid....the controller valve where the stick goes into the valve is blowing out fluid....Oh poop. Called dealer....going to pick it up next week. Still love my MT225S.
   / What did you do on or to your LS Tractor today? #1,854
PUT THE PHD ON TODAY,,A REAL P.I.A... I AM SURE I DID NOT DO IT IN THE CORRECT ORDER,,BUT I DID MOST STEPS TWICE,AT LEAST..THE BALLS IN THE QUICK COUPLER WERE KINDA STUCK,,SO WAS A REAL WRESTLIN MATCH TO GET THE PTO SHAFT ON..ONCE ON IT WORKS JUST FINE.. HAPPY WITH IT..
   / What did you do on or to your LS Tractor today? #1,855
I echo what others have said from my own experience. I used to have a small you tube channel where I did farming simulator videos, but the advice I'd get was the same. You are always your own worst critic!
I no longer record gaming, but was obsessed with having the perfect audio, editing out every time my dog barked or whatever thing I was obsessing about, the bottom line is if people are enjoying your content, keep the focus on what people seem to enjoy, and improve the other stuff when you can as you progress along. Sounds like you've got the idea: Focus on improvement, but don't stress imperfection.
   / What did you do on or to your LS Tractor today? #1,856
Thank you! I really do appreciate it. In fact, I just uploaded the next video, complete with voiceover! :censored:
But going back on topic, yesterday, I removed the hydraulic top link, and the side links, to hook up to the backhoe. I did use the hooks and balls, and the hydraulic top link while mowing. Mowed a ton around my property. But now, I gotta get the stumps removed. Too many to count! I really need a ripper tooth, and I did find a fabricator (I believe on here) that makes ripper teeth for my BH, but wants $1000 for it!! Yikes!
If anyone knows of someone else....?
Or I gotta make my own.
   / What did you do on or to your LS Tractor today? #1,857
I didn't even know what a ripper tooth was, but after a google search upon seeing your post I see the value in this. I found this video, seems easy enough for a homemade project that just needs to meet farmer DIY quality, I'm going to be looking at doing something similar myself.
I think for me I'm going to try something else out first after getting the idea from your post, I think I could do without needing the ripper tooth, if I just add some type of smaller teeth edging on my bucket to allow me some sawing power, similar to what a stump bucket for a FEL looks like. My roots aren't large or deep, but I think something like that could help. I wonder has anyone tried that, or should I just skip that and also get a ripper tooth? Curious to know what yall have done that have backhoe often used for stump removal.
   / What did you do on or to your LS Tractor today? #1,858
That's definitely a good practice project, now that you have the welder. And would make for a good series of videos. 👍
In case you don't trust your welds yet, just add more gussets and more welds. 😅
   / What did you do on or to your LS Tractor today? #1,859
Oh, I trust my welds! I've been welding for years! ;)
And you're absolutely right, about making my own, the videos, and a fun project. Its just going to be the time put into it that I'm short on. I'm willing to pay someone to make it for me, type of thing, and spend my time on other projects or with my family. But, if I cannot find one, reasonably priced, then I'll have to make one. I'm currently waiting on a quote from the steel store to laser cut a 1" thick ripper shank out of Hardox 450. 😁
   / What did you do on or to your LS Tractor today? #1,860
One thought is you could look to buy something like this, then work to make it fit on your backhoe, basically you buy the tooth/ripper part, modify it to fit on your backhoe. I'd guess that would be too small so you'd have to either torch off the top bit, or just keep it and build it out so it's wide enough to fit what you need.
This might be cheap enough I'm thinking about doing just that. I found an even cheaper looking version on eBay, might be willing to try that and see how it holds up.
Should save lots of time fabricating the curvy part and just work on making it fit to your machine.
Miller Big 40 Portable DC Arc Welder Generator (A55973)
Miller Big 40...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2016 UTILITY 53X102 REEFER TRAILER (A59905)
2016 UTILITY...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
