npalen
Elite Member
I did try the -1 setting parameter F7 but to no avail. At this point I'm thinking that this parameter, which is defined as a stratification adjustment, simply compensates the temp sensor depending on how high on the wall the unit is mounted. For instance, the setting for accurate temp sensing would be much different if the inside unit was mounted fifteen feet versus six feet above the floor where it would be sensing the cooler air.I will try a -1 on the F7 setting. I kind of gave up on the idea of trying different adjustments after thinking more about the "stratification" associated with the F7 description thinking that it was futile.
Just getting into parameter adjustment mode is quite an undertaking with shutting down, pulling batteries out of the remote etc.
Cielo Breez Plus
Make any ductless air conditioner smart with Cielo Breez Plus. Offers next-gen features including scheduling, geofencing, air filter status & more.
Perhaps the Cielo does a better job of modulating the compressor output. Don't know, probably just have to try it. The current level of comfort can only be achieved by constantly changing the set temp.
