kubota g5200
/ kubota g5200 #1
MRFUNKTASTIC
HASTINGS, FLORIDA
KUBOTA G5200
I have a kubota g5200 garden tractor that I would like to get a deck back under. Im good at fabricating. I love this little tractor.
I was wondering if anyone has a kubota mid pto 60 inch deck on there tractor and could help me out if you would please. I was wondering the rotation of the pto shaft on the deck. I was wondering if on some of the decks where the gearbox points to the back could be spun to the front and keep the proper rotation.
Any help would be greatful. Thanks a million
/ kubota g5200
Okay that's great news! I was hoping the rotation was the same. It's hard to find a good rc48g deck to go under the g5200. I figure I would just find another model deck and make it fit as far as brackets. Not sure about the pto shaft yet. It's also impossible to find any pics of attachment points.
How do you like the g5200? Does it cut good? It seems like the little tractor would be a beast as a mower.
Thank you so much for the reply!
/ kubota g5200 #4
I don't mow with it often, I use my BX2380 the most. I still have it because it looks like new yet. Phone Pics 006 (5).jpgPhone pics 086.jpg
/ kubota g5200 #6
Thanks. I do take pride in my equipment. I like to mow with it now and then, cuts great, very comfortable to use. I did take the slack out of the steering system, makes it much nicer to use. It is a working museum piece, kind of.
/ kubota g5200
I really like where the battery is placed. Makes it to where the radiator can breath better. Never thought of putting it there.
I hope to restore my kubota to that level someday. It's in a hundred different pieces cause I'm taking it apart to restore. It was at my dad's sitting under a carport for the last 5 years. Put new diesel in it and it started back up.
/ kubota g5200 #8
I put the battery there after replacing the original equipment style battery too many times, I put a group 24P out front and that was the end of my battery problems. It was good ballast when I used my fully mounted sprayer on the back. Shortly after I bought it in 1993 I put the hydraulic deck lift kit on it and bought a bagger for it also. The 44" deck in heavy grass and the bagger, made it snort a bit. I bought a BX2200 to mow with in 2002, nice machine, but the G5200 was more comfortable to drive. As you can see in the picture, I kinda like Kubotas.
/ kubota g5200 #9
I have a G6200 which is 2 hp bigger with a 48" deck, I think a 60" deck would be cumbersome, and probably taxing the engine in certain grass.
/ kubota g5200
It might drag it down a little now that you say that. I need to do some more research on around as close if not dead on to 48 inch cut. You can find tons of the 60 inch decks.
What model decks are there for the 48 inch decks?
/ kubota g5200 #11
I found a fairly fresh RCK48-15BX (BX1500) on from CL for $300, early last winter, which I got as insurance.
The gear ratio is really close, so blade tip speed should be good, and I really like the double V belt & pulleys - a much stronger arrangement.
Plan A: Swap it for my G5200's RC44-G Frankendeck, whenever the remaining steel that holds the weld & braze patches together goes all big bang on me.
I'd need to flip the gearbox around (fore to aft) and add/modify the tractor mounting brackets.
Then there's the PTO shafting - I'd need to get creative with that, as they're different sizes.
Plan B:
The perimeter, caster frames & tractor mounts on the RC44-G are still solid, so another option would be to cut the rotten top off.
Then cut the perimeter into 2 or 3 pieces to fit the RCK48-15BX top and center distances, retaining the RC44-G's mounts. More complicated, but might fit up to the tractor better.
Jim
/ kubota g5200
I've seen where there are a bunch of decks with the gearbox towards the rear tires. Should be easy enough to flip the gearbox forwards.
I think what you've got going seems like a good idea and can be made to work.
I've thought of just getting the spindles and gearbox for the g5200 and just getting any deck and just fabricate till I make it work.
/ kubota g5200
Well I guess I'm not going to put a deck under my g5200. I just inherited a kubota b5200 with a belly mower. It all worked out in the end I guess. I will use my g5200 to pull a trailer around the yard I guess. The b5200 is in real good shape. 1 small rust hole in the deck. But going to take it apart and rebuild spindles and fix and stop all rust on it now before there's no deck at all.
There's a little bit of wiggling on the front pto shaft where the deck attaches. I'm ordering all new bearings for the complete unit.
/ kubota g5200 #14
Old Post, but thought I'd try. What bagger system did you put on your g5200
2023 GERINGHOFF PATRIOT RD8R30" CHOPPING CORN HEAD (A64278)
2023 GERINGHOFF...
2022 Mack Pinnacle T/A Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
Front Tank Bracket (A64126)
Front Tank Bracket...
2011 Ford F-150 Pickup Truck (A64194)
2011 Ford F-150...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A67147)
2016 INTERNATIONAL...
