Battery based electric vehicles of today and tomorrow.
Status
Not open for further replies.
/ Battery based electric vehicles of today and tomorrow. #2,141
... If built in a union shop. Too bad Musk has been ranting against unions.
I've been fascinated by the Tesla Model Y. I'm waiting for it to get beyond the random assembly quality that Consumer Union says disqualified it from a recommended rating. However - just this week Tesla announced models 3 and Y will no longer have the radar sensors that can see through rain, and see the second car ahead. Just camera sensors that a reviewer said are useless in rain. Not even the cruise control was usable. That's not as attractive.
Only $2,500 of the $12,500 rebate will not be available in the proposed rebate because of non-union.
Cruise control should not be used in the rain in any vehicle per most owner's manuals.
From the Tesla model 3 owners manual page 87"
"Traffic-Aware Cruise Control is primarily intended for driving on dry, straight roads, such as highways and freeways. It should not be used on city streets."
/ Battery based electric vehicles of today and tomorrow. #2,142
Looks like a strong offering to me - especially if the "shorter/medium range"/230mi version is substantially cheaper than the long range: I don't know that we have much of a use for that extra range, and if I can get a reasonably optioned (ie, not super lux) truck that can go 200mi that may just be sufficient for us.
The extended range with it's extra acceleration (the standard one is faster than you really need as it is, and I've got a motorcycle if I feel the need) probably has a lot of standard fancy stuff, and even if it doesn't, it's a fair chunk of change on top of the shorter range. I'm not convinced of being able to drive 560 miles in one day in an electric vehicle for the time being (distance from home to a city we drive to once or twice a year because of reasons), since a "300 mile" range vehicle will likely need 2 recharges to get you there (my wife demands the fuel tank not drop below 25% now, so that 300mi becomes a stop around 225mi and 450mi, +/- depending on availability of chargers) and two 45+ minute charges adds a lot onto that trip that's already a stretch for us in one day. The "230 mile" range would require a stop at 170, 340, and maybe 510 with the same 75% requirement, though it could probably be more reasonably stretched to also only need two stops for that trip, which means that its reduced range wouldn't be seen in our use case.
If you do more than a small amount of towing (eg go to the dump, short-distance camping) these should be fine. Longer towing hits them like it does a gas truck, except that this truck takes a lot longer to refuel. We don't do much trailering any more, so this doesn't matter in our equation.
Regardless, I won't be getting rid of my '97 F350 4x4 CC LB, though it may get even less use if we get this truck!
This is a Ford dealership in AL.
/ Battery based electric vehicles of today and tomorrow. #2,145
These estimates make the common mistake of projecting forward while assuming we’ll still be under the exact same constraints of today. That’s not how the future works. By 2050 I have absolutely no doubt whatsoever that instead of me pulling 1500 kWh every month from the grid, I’ll be pulling zero, or more likely feeding some back. That’s not some pie in the sky pipe dream - many people are doing exactly that today. If you look at how the price of solar is dropping and how installations are growing, it’s not unreasonable to see a future where the grid will need less capacity, not more.
You apparently live in a state where the sun shines. 😜😜
Hopefully there is a rain cell invented by 2050. 🤣
I listen to this guy some times and like him. His take on the proposed EV federal rebate hurting Ford and GM is not clear yet in my mind.
/ Battery based electric vehicles of today and tomorrow. #2,147
You wouldn’t know it based on our recent weather but down here in Oklahoma we’re in pretty prime solar country. I spent a lot of time where you’re at and going solar there might be a bit more challenging ;) Absolutely beautiful though.
/ Battery based electric vehicles of today and tomorrow. #2,149
I'm amused by a couple statements in the video (paraphrased as I watched it and now I'm back here and didn't write anything down while watching):
"people are concerned that electric will add a lot of weight and compromise the 4x4 capabilities ... but this offers the highest power-to-weight ratio of any utv" :: higher power-to-weight doesn't necessarily make it a better 4x4. Not saying it won't be, because there are probably heavier jeeps that are better 4x4's than this thing, but just sayin', the p/w ratio isn't necessarily an answer for the concern
"strongest utility drivetrain" - with more powerful motors, it better be a stronger drivetrain! Their point was that it has fewer moving parts, so less things to break of course, but I hope they've beefed up the drivetrain to handle what's likely a substantially higher torque (at least before gearing). If they really want to reduce moving parts, they could use multiple motors and eliminate differentials, but I see at least one diff at the rear and have no idea if there's one in the middle as well still.
That criticism aside, this seems like a great purpose for electrical. I can see a portable unfolding solar array that you unfurl at your campsite to charge up your truck's battery during the day, and at night you recharge your e-UTV from your truck (considering an e-UTV's battery is likely to be a smallish fraction of a truck's battery)... probably even better as a ranch UTV, since you're even less likely to go 40 miles.
/ Battery based electric vehicles of today and tomorrow. #2,150
The main issue I see with this UTV is if hunters are in a secluded deer camp with no power say for 1-2 weeks how would you charge this UTV ? How long does the charge last? Our deer camp has wood heat propane lights and NO power..I think makes ford150 model that has some type of generator on they're new trucks but not everyone owns one of those models.
Deer hunting style in my area is a pickup truck pulling a trailer parked on the side of the road.
/ Battery based electric vehicles of today and tomorrow. #2,153
That’s probably more of a fringe case where a gas UTV would be a better choice. My deer hunting is limited to the south and east and I’d wager the overwhelming majority have access to an outlet at night. As long as you can plug in somewhere, the near silent operation combined with no more smelly gas and exhaust fumes would make this a very stealthy hunting machine.
/ Battery based electric vehicles of today and tomorrow. #2,155
Not really a fringe case many deer camps in northern MI. do not have power.Old school I guess.We hoof it back in by foot a 1/2 mile to mile verses the stealth approach.Nice to get away from the cell phones and the gloom and doom nightly news casts.(y)
/ Battery based electric vehicles of today and tomorrow. #2,156
1/2 mile must be considered a long distance east of the Mississippi. 😋 It is nice to get away from the modern "conveniences" for sure.(y)
I am starting to wonder if this EV tax credit may help China companies the most. Already Tesla is selling everything they can build. The Ford F-150 Lighting production will be limited until they build battery factories. China has EV car and battery factories on line already plus they control much of the raw materials needed by EV battery factories.
/ Battery based electric vehicles of today and tomorrow. #2,159
No thats a old farts hike when you get over 60 if the snows 2 ft deep.
/ Battery based electric vehicles of today and tomorrow. #2,160
I saw my first Tesla yesterday. A fellow over from Seattle was visiting here in Cheney. It was the sport model. They are much nicer looking, up close, then on their TV commercials. I am very impressed.
Much too low slung to go on my driveway but as long as you don't venture off the asphalt - a fine looking vehicle.
Status
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2025 IREV Electric Scooter (A64194)
2025 IREV Electric...
3PT WEIGHT DRUM W/ CONCRETE FILLER (A63291)
3PT WEIGHT DRUM W/...
Wolverine Towable Log Splitter (A64047)
Wolverine Towable...
New Holland TS6.110 Tractor with Alamo Boom Mower (A64047)
New Holland...
