Grapple for JD 2720
/ Grapple for JD 2720 #1
jkb7810
Member
denison,ia
john deere 455, 2720, 4020, 7810
Looking for some information from the guys that have a 2720 or similar size tractor. 2k ish lbs fel 800lift capacity.
Been looking at grapple's again and kinda stuck on the 48 titian 450 lbs. EA said 12 to 15 weeks back log 55" 300lbs.
Plus try to justify an extra 1k $ is kinda hard to swallow. Have not tried any one else. Did look at MTL and there weight is around 350. Of course the lighter grapple's are not made with the same steel thickness.
What your thoughts on grapple's.
/ Grapple for JD 2720 #3
You DO NOT want a 450 pound grapple on a compact tractor, much less an imported one!
Look at Artillian as tiller mentioned, EA, or CTA (Compact Tractor Attachments)
Wait time are increasing for everyone now, material/supplier issues and high demand are only part of the reason, plus the longer you wait the more the price will go up.
I'll check those out. Thanks guys.
I have a quote coming for the 50in grapple from CTA. Pretty sure I'm going with them.
Now all I have to do is get the power beyond and valve's put on. O yeah and gripe about the 100lb weights I put on it. LoL .Pretty sure I have all the parts for it. Just have to build the bracket's.
Just a update. I've got the grapple here and it really looks great. Now I just have to find the time the make the bracket for the valve and a location. Not much room on these little things. LoL
Well I have finally got around to building the bracket for the 3 spool valve I bought. Here are some pictures of the mock up.
My plan from the original idea has changed so I will have to get some other fittings, when the plumbing starts.
I also took a picture of the 100lb weight that I spoke of earlier. Finger pinching, #!#!#! U get the drift. 🍺
/ Grapple for JD 2720 #10
I've never seen a weight for the front like that. Tell us about it.
Also, I like your grapple project, wish i had one sometimes.
/ Grapple for JD 2720 #12
I think those wheel weights are on the rear tires - bigtiller. Take a close look at the first picture posted. You can see them clapped on the rear tires.
/ Grapple for JD 2720 #13
Oh yeah, I see it now. Thanks oosik
Bigtiller, the weights are off a old JD combine . There right around 100lbs each and make a big difference for stability with the FEL. I will have to remove the right rear from my 2720 to get access to the hydraulic block.
We guys here is an update on the progress.
I've started the plumbing and of course, missing a couple of things. Here are some pictures that I can check out and give me some feedback on. Also, here is a link to some of the information that I've been going by.
I've got it a plumbed and been using it some.
Going to make a bracket for FEL lines and I did put QD's buy the other ones.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
2017 Lincoln MKC Multipurpose Vehicle (MPV), VIN # 5LMCJ2C95HUL50284 (A65563)
2017 Lincoln MKC...
2005 International 4300 Rollback (A62613)
2005 International...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
2003 Kenworth W900 L Model (A62613)
2003 Kenworth W900...
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
